Please Help Identify year of B18b lots of pics
Old Nov 4, 2016 | 06:10 PM
BoRiCuA's Avatar
Icon5 Please Help Identify year of B18b lots of pics
Size:  1.58 MBName:  IMG_4551.JPG
Size:  1.39 MBName:  IMG_4552.JPG
Size:  1.31 MBI bought all disassembled and the guy doesn't really remember the year or if it's obd1 or obd2.
Old Nov 4, 2016 | 06:11 PM
BoRiCuA's Avatar
Default Re: Please Help Identify year of B18b lots of pics
Size:  1.30 MBName:  IMG_4554.JPG
Size:  1.26 MBName:  IMG_4555.JPG
Old Nov 4, 2016 | 06:12 PM
BoRiCuA's Avatar
Size:  1.65 MBName:  IMG_4557.JPG
Old Nov 5, 2016 | 06:56 PM
BoRiCuA's Avatar
anyone?
Old Nov 6, 2016 | 12:09 AM
Benny Honda's Avatar
5 Year Member
Pre-96 is all I know. At least the head is.
Old Nov 6, 2016 | 01:27 AM
BoRiCuA's Avatar
The confusing part for me is that i believe this is an obd2 valve cover but it has an obd1 dizzy ( 2 plugs) also an obd2 iacv. The knock sensor is also not on the block like obd2.....ughh
Old Nov 6, 2016 | 10:08 AM
5 Year Member
I was under the impression all the obd1 b18b valve covers looked like yours and all the obd2's looked like mine (in picture), but maybe I'm wrong. Mine is marked P75-2 above the header. This is the original 1997 obd2 b18b1.
Old Nov 6, 2016 | 02:18 PM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Is there a VIN # down by the oil pan on front of block? Punch that into a Honda/Acura online parts store and it will tell you the year of the block...
Old Nov 6, 2016 | 03:12 PM
BoRiCuA's Avatar
There's gotta be another way, aren't valve cover's interchangeable thou? someone has to know, there's has to be a way to absolutely know.
Old Nov 6, 2016 | 03:14 PM
BoRiCuA's Avatar
The reason for me saying that is, obviously not original VC.....
Old Nov 6, 2016 | 03:16 PM
BoRiCuA's Avatar
No vin # just checked.....
Old Nov 7, 2016 | 08:29 AM
thaiphob's Avatar
Nikon!!!
From the head stamp, ( the (9/7) between the 3 & 4 exhaust ports ) it appears to be a 1997 motor.
Old Nov 7, 2016 | 11:44 AM
GreatWave's Avatar
10 Year Member
That block is OBD1 (94-95), valve cover is OBD1. throttle body is OBD2 (lacking FITV), intake manifold is OBD1, head appears to be from '97 as stated above (OBD2).
Old Nov 7, 2016 | 04:48 PM
BoRiCuA's Avatar
Everything is obd1 except head and throttle? wtf so because there is a 9/7 it states it's a 97 obd2 but it has obd1 dizzy on it?
Old Nov 8, 2016 | 05:09 AM
GreatWave's Avatar
10 Year Member
That's what it looks like to me. Somebody probably cobbled it together over the years. I did the same thing in my Civic when I was on the hunt for parts. Most everything will interchange between the two.
Old Nov 8, 2016 | 05:18 PM
BoRiCuA's Avatar
No seriously, i know that a lot of parts are interchangeable but i never thought an obd1 dizzy would work on an obd2 head. The freakin trans is a y1, which makes it an Sir trans that came from an obd0 b16 and i dont know which clutch to order wtf.....
Does all this make sense... ... ...
Old Nov 8, 2016 | 06:35 PM
GreatWave's Avatar
10 Year Member
I've always ordered the clutch for the trans
Old Nov 10, 2016 | 03:17 AM
BoRiCuA's Avatar
Jdm Sir Y1 without lsd, so what year clutch do i order?
Old Nov 10, 2016 | 05:22 AM
GreatWave's Avatar
10 Year Member
Is it cable or hydro?
Old Nov 10, 2016 | 05:15 PM
BoRiCuA's Avatar
cable
Old Nov 10, 2016 | 06:03 PM
TheShodan's Avatar
Moderator
90-93 Integra cable clutch.. Problem solved.
Old Nov 10, 2016 | 06:18 PM
BoRiCuA's Avatar
I know engine doesn't matter, but what about the flywheel, is it also 90-93 for b18b?
Old Nov 10, 2016 | 06:42 PM
TheShodan's Avatar
Moderator
Think about how it all connects together. Same for pressure plate is the same for the flywheel.
Help me out with this please, you just can't post problem solved and disappear....lol will this work for a b18b http://www.ebay.com/itm/EXEDY-CLUTCH-PRO-KIT-HD-FLYWHEEL-90-91-ACURA-INTEGRA-RS-LS-GS-B18-JDM-B16A-Y1-S1-/162260048546?hash=item25c773daa2:g:W9gAAOxyhlJRbyd Y&vxp=mtr
If you're a Cable transmission , you use a cable clutch/ flywheel combination. You don't use eBay to find the right clutch because they use 50 different naming conventions as a general search result.
Go to Exedy's site to confirm and not eBay.
Last Spoonful - Part # 0802B Is the basic Exedy/OEM clutch match. Works for that year 92-93 Integra B18BA1 . They share the same years as 1991. Everything lines up. Clutch/flywheel combination. Any stronger, and you may convert to Hydro later.
This is the OEM Clutch replacement
http://www.gearspeedwholesale.com/product_p/08028.htm
This is the Stage 1 Clutch
Exedy Part #08804
https://www.amazon.com/EXEDY-08804-R...ype=automotive
To Verify, check out the official Exedy catalogue. Always confirm your searches OUTSIDE eBAY designations.
https://www.exedyusa.com/new-2016-exedy-racing-catalog/
I can point in the right direction and lead you to the path of the water. Doesn't mean I have to walk you there and point to the lake.
Enjoy, my friend.
Old Nov 11, 2016 | 04:08 AM
BoRiCuA's Avatar
Thank you Sir
Old Nov 13, 2016 | 01:48 PM
Scorchin Civic's Avatar
Just a FYI, all B18 and B20 distributors will bolt up to the head. However, it all has to do with what wire harness you have that your working with. In other words, OBD0, OBD1, or OBD2. A lot of parts are very interchangeable for all 1990 - 2001 B18s and 1997 - 2001 B20s as well.
