Please Help Identify year of B18b lots of pics
I bought all disassembled and the guy doesn't really remember the year or if it's obd1 or obd2.
Re: Please Help Identify year of B18b lots of pics
I was under the impression all the obd1 b18b valve covers looked like yours and all the obd2's looked like mine (in picture), but maybe I'm wrong. Mine is marked P75-2 above the header. This is the original 1997 obd2 b18b1.
Premium Member
Is there a VIN # down by the oil pan on front of block? Punch that into a Honda/Acura online parts store and it will tell you the year of the block...
There's gotta be another way, aren't valve cover's interchangeable thou? someone has to know, there's has to be a way to absolutely know.
Everything is obd1 except head and throttle? wtf so because there is a 9/7 it states it's a 97 obd2 but it has obd1 dizzy on it?
Does all this make sense... ... ...
Moderator
Originally Posted by TheShodan
Originally Posted by BoRiCuA
Help me out with this please, you just can't post problem solved and disappear....lol will this work for a b18b http://www.ebay.com/itm/EXEDY-CLUTCH-PRO-KIT-HD-FLYWHEEL-90-91-ACURA-INTEGRA-RS-LS-GS-B18-JDM-B16A-Y1-S1-/162260048546?hash=item25c773daa2:g:W9gAAOxyhlJRbyd Y&vxp=mtr
Go to Exedy's site to confirm and not eBay.
Last Spoonful - Part # 0802B Is the basic Exedy/OEM clutch match. Works for that year 92-93 Integra B18BA1 . They share the same years as 1991. Everything lines up. Clutch/flywheel combination. Any stronger, and you may convert to Hydro later.
This is the OEM Clutch replacement
http://www.gearspeedwholesale.com/product_p/08028.htm
This is the Stage 1 Clutch
Exedy Part #08804
https://www.amazon.com/EXEDY-08804-R...ype=automotive
To Verify, check out the official Exedy catalogue. Always confirm your searches OUTSIDE eBAY designations.
https://www.exedyusa.com/new-2016-exedy-racing-catalog/
I can point in the right direction and lead you to the path of the water. Doesn't mean I have to walk you there and point to the lake.
Enjoy, my friend.
Just a FYI, all B18 and B20 distributors will bolt up to the head. However, it all has to do with what wire harness you have that your working with. In other words, OBD0, OBD1, or OBD2. A lot of parts are very interchangeable for all 1990 - 2001 B18s and 1997 - 2001 B20s as well.
