Honda CR-V & Element 2WD & 4WD Element & CR-V
'01 CRV Diagnosing Low Compression
Old Nov 2, 2016 | 09:57 AM
FlipMode01's Avatar
Default '01 CRV Diagnosing Low Compression
I have an '01 CRV LX (B20Z) 265,000 miles with low compression on cylinder #1. Compression is only 50 psi and leakdown test show 60% leakage on cylinder #1. Check engine code show P0300, P0301,P0303. When I send compressed air down the cylinder #1 spark plug hole I feel air coming out of the exhaust pipe. Before I remove the cylinder head to service the valve, I was wondering how can I diagnose if there are problems with the bottom of the engine like the piston rings. Is feeling for air coming out of the top of the dipstick tube a good diagnosis of low compression due to bad rings for this engine?
Old Nov 2, 2016 | 12:58 PM
Cayton's Avatar
Default Re: '01 CRV Diagnosing Low Compression
I don't know about the dipstick tube causing low compression but I do know a somewhat common problem with these 1st gens is the dipstick tub separating from the bottom part. It happened to my 2001 EX just the other day. I pulled the dipstick out to check the oil and the tube came out with it! After a quick search I learned to take off the exhaust manifold cover and press the tube back on. I had to drive less than a mile from the gas station where this happened and when I got home there was oil everywhere. The fix itself was super easy. Good luck.
Old Nov 3, 2016 | 08:32 AM
EJ8_Man's Avatar
It sounds like you have a bad valve. Perform a leak down test. Google a how to video. You can rent the tester from an auto parts store
02BladeRider
Jul 7, 2017 05:49 AM
BIG T
Nov 17, 2007 11:30 PM
cxVtecC1
Feb 18, 2005 06:54 AM
imgonnalie2u
Jan 11, 2005 08:05 AM
Death_to_Thieves
Sep 25, 2002 12:49 PM
