Transmission slipping
Old Oct 31, 2016 | 07:57 AM
Randi Geiselman's Avatar
Default Transmission slipping
I have a 2001 Honda accord lx. The transmission seems to be slipping. I was told my catalic converter could be the issue... Is that possible?
Old Nov 1, 2016 | 02:36 AM
holmesnmanny's Avatar
Default Re: Transmission slipping
No.
Old Nov 3, 2016 | 08:29 AM
MAD_MIKE's Avatar
MM Gruppe B
Verify AT fluid level is full and fluid condition.
Verify CEL/D4 lamps work.
Check for any stored codes via the OBDII port.
Old Sep 18, 2017 | 09:21 AM
Spudz76's Avatar
If the 2001 still has a modulator cable, check that. I think maybe they quit with the cables after 97 or 98 though. If it's there, and too loose, you'll never get proper line pressures going.
Old Sep 20, 2017 | 05:43 PM
MAD_MIKE's Avatar
MM Gruppe B
USDM Accords used the H4A with the throttle valve cable from 90-97 in the 2.2 cars. In '98 the trans was fully computer controlled and the TV cable was replaced with a pair of linear solenoids.
bobinda808
Mar 8, 2009 09:02 AM
LX4CYL
Feb 13, 2005 03:16 PM
hikingauto
Jul 11, 2004 09:29 AM
EKtypeRhaTcH
Jul 6, 2003 06:46 PM
Rice4me
Jul 4, 2001 05:24 AM
