Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
passenger side low beam not working
Old Oct 23, 2016 | 05:05 PM
standerby's Avatar
Default passenger side low beam not working
My passenger side low beam is not working. However right low beam is working, and both side high beam are working. I swapped left right side bulb and fuse. The problem remains the same. So it's not bulb and fuse problem. What else should I look at?
Old Oct 29, 2016 | 03:31 AM
poorman212's Avatar
Default Re: passenger side low beam not working
Have a volt meter?
Test to verify if you are getting power and ground - the ground "point" for low is the same as high so it should be good but you have to verify there is not a "break" in the wire going to the ground point.
Kirk Hoey
Honda Civic (2001 - 2005)
Sep 28, 2019 11:25 AM
UrbanLungs
Jun 5, 2017 08:36 AM
EX-T
Oct 7, 2010 11:42 PM
woodwardba0526
Mar 29, 2010 05:15 PM
powerwagon340
Dec 24, 2008 01:07 PM
