BeaterBoost's Built D16Y8 Novice thread
So I have a eh civic that I got from a buddy who built it with all new forged internals and a fully built head with titanium springs and retainers and turbo cam and ported and polished and has a xtd stage 4 clutch. Now my issue is the clutch is slipping cuz the buddy I got it from didn't know you have to break in a clutch when you install it and I wanna push as close to 400hp as possible. So my question is what all do I need to do to push it there and what parts are gonna be best and also since the clutch is slipping what is gonna be the best to handle the power and torque and abuse from not only dd but from track use. Thanks in advanced!
XTD clutches are junk, even if he didnt align it properly its most likely too late to go in there and re align it now.
transmission has to come off so its a big job either way, look around theres a how to thread here,
I made 400 HP on my exedy satge 2 havent had a single issue with it, I would recommend a clutch master fx400 thats what Im going with next time
ive seen people have luck with them but its still an ebay clutch
I admit your info holds more weight then I do, I have no personal experience with them and i never will
OP if you go with a cheap *** xtd at least resurface your flywheel and install it properly. Also go with the unsprung disc as there are many cases where the springs pop out on the sprung versions. I have a feeling you're going to cheap out and get an xtd going off your screen name lol.
As for info on your actual turbo setup check FAQ sticky at the top.
@boosted what clutch went on your latest build?
just curious....could this possibly somehow be the issue with the knocking noise your trying to chase down
Its a xtd stage 4 unsprung 6 puck. I think it's the only cheap part on the whole build lol. I don't see how the clutch could possibly be making the noise I'm chasing. It shifts super smooth, nothing weird with clutch engagement or anything.
Idk man I have a bad feeling it's the oem LSD making the noise. The only time I can duplicate the sound 100% of the time is when turning and unloading the drive train, any other time it's random. It's very distinct like someone is tapping the shift linkage with a hammer a couple times in a row. A like a gear missing teeth is all I can think of that would make that kind of noise.
The issue is obviously not the clutch its self but the break in meathod was not done correct. As mentioned previously, an Exedy stage 2 or clutch master FX400 are good units. The S2000's from LHT running 400 WHP with their supercharger packages run the Clutchmaster Fx400 Clutch.
ej8kid97
Apr 8, 2016 08:03 AM
pjr710
Jul 23, 2008 09:53 AM
