Changed Hydrualic Clutch but feels like its forced when running
I was drving my car when it stopped shifting gears. I knew I had to change the clutch for some time now so I went ahead and did that. It took a while for the clutch to get pressure when I bled out the fluid. When I turned on my engine and tried to drive it feels forced. I can shift gears with out a problem but it just feels as if it is running forced. Anyone have any idea what can be the problem?
You need to take the time and describe your problems. Do you mean it feels like you have to force the shifter into gear with the clutch pressed?
1995 Ford Mustangs are susceptible to clutch issues.
