not able to pull codes
Old Oct 9, 2016 | 06:38 AM
shagginwagon's Avatar
Default not able to pull codes
I recently purchased a 95 wagon and the guy i purchased it from did a motor swap on it. everything runs, but the idle is off and some check lights are on. issue i am having is when i try to pull the obd1 codes and see what errors are coming up nothing is being read at all. anyone have any ideas on what i can do?
Old Oct 9, 2016 | 04:26 PM
tamboo's Avatar
10 Year Member
Default Re: not able to pull codes
had an issue where i could only pull a code with the engine running otherwise no dice.
ymmv.
Old Oct 9, 2016 | 05:56 PM
holmesnmanny's Avatar
engine can be off or on, just the ignition has to he on
it's possible he disconnected the check engine bulb
Old Oct 9, 2016 | 06:51 PM
the check engine lights come on but when i try to pull any codes nothing reads. is it possible the computer he used for the swap just isn't the right computer?
Old Oct 10, 2016 | 04:28 AM
are you jumpering the blue service connector with the ignition on ?
Old Oct 10, 2016 | 07:28 AM
yes sir still no go. reason i was trying to get codes pulled is the idle on the car isn't right so its bogged down when accelerating and deaccelerating
Old Oct 10, 2016 | 07:33 AM
ISUBIEXI's Avatar
Just to be clear... the check engine light stays on when the car is running?
Old Oct 10, 2016 | 08:05 AM
yes sir along with the abs light
Old Oct 10, 2016 | 09:33 AM
ISUBIEXI's Avatar
What motor did he swap in? Check the ECU and see which one it is, also while you are there look at the connectors and see if anything looks hacked together. Should be OBD1 with OBD1 ECU.
Old Oct 19, 2016 | 06:57 AM
confirmed it yesterday it is a f22b swap and the ecu he used was the stock ecu that initially came with original motor so now i am on the search for a f22b ecu
tylerzero
Honda CR-V & Element
Oct 27, 2022 07:21 PM
fadedcrx
Oct 2, 2013 08:33 AM
clash
Jun 28, 2005 11:50 AM
lsvtec101
Apr 4, 2003 11:20 AM
