How to tell if a GSR head has auto cams or manual cams
Old Oct 4, 2016 | 03:08 PM
Hatchg's Avatar
Default How to tell if a GSR head has auto cams or manual cams
Just got a jdm b18c long block from a very trustworthy and reputable supplier (hmotorsonline). He gave me the choice of a motor with manual cams or auto cams, with auto cams having a less aggressive lift profile for lower rpm. I chose manual, but my question is: how would you tell the difference beetween the two without actually measuring the cam lobe. Is there a certain stamp on the head or something?
Old Oct 7, 2016 | 01:00 PM
thewrai6th's Avatar
Default Re: How to tell if a GSR head has auto cams or manual cams
The part # would be stamped on the cam, not the head. But I do not think Honda cams are stamped with part #. You may have to identify them visually like this:
https://honda-tech.com/forums/acura-...hafts-1220152/
If you feel like pulling them out and posting a pic, someone can probably identify them for you.
Old Oct 7, 2016 | 05:53 PM
Hatchg's Avatar
Yea, i can't actually take them out of the head or it voids the warantee. I can take the valve cover off and turn the crank to rotate the cams to see it, unless the number is under a cap or something. Do you know where the number would be on the camshaft?
Old Oct 19, 2016 | 02:42 AM
PHAT-INTEGRA's Avatar
Why does cams matter if it's auto or manual? Please do explain because I love some one explain this to me
Old Oct 19, 2016 | 07:39 AM
Hatchg's Avatar
This is only what i was told by my motor importor. I am not claiming to know for a fact. Honda made a jdm specific SiR model crx or something, dont quote me on the model. But it used a b18c gsr with an auto transmission. Honda used cams with a less aggressive lift profile on these motors and the redline is 7000 instead of 8000. Other than that I believe there is no difference
Old Oct 19, 2016 | 02:23 PM
thewrai6th's Avatar
Previous post is correct, as far as I know. There was a SirG (GSR) auto in JDM.
As far as the differences, it will be lift, degree and duration of the lobes on the cam. You'd have to get out the micrometer to check the specifics.
Old Oct 19, 2016 | 08:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yep have to pull the cam cap off and check the end ive never seen anything on indentifying Auto GSR cams, but wouldnt be hard to swap them out for usdm gsr cams if there not but they will void your warranty but i wouldnt worrie about it they should of sent the correct engine you paid for.
Old Oct 20, 2016 | 02:32 AM
I know there was a SIR-G Automatic in Japan. Japan and USDM Cams will have different specs. There is VTEC and Non-VTEC cams but never heard of auto/manual cams.
You take a LS/RS/GS/SE manual and a LS/RS/GS/SE Automatic will they have the same cams? yes it will have the same spec cams it does not matter if it's auto or manual there all Non-VTEC cams.
Then you take a JDM SIR-G manual and JDM SIR-G Automatic they use the same Engine spec (same cams spec). The only different is the ECU and Transmission.
Old Oct 20, 2016 | 09:50 AM
thewrai6th's Avatar
My guess would be different power band/ECU, redline is 7000 for the JDM auto?
As far as USDM models, you are correct, they are the same part #.
Old Oct 20, 2016 | 10:55 AM
tony_2018's Avatar
Fish Twig
You have to pull cams to identify.
Old Oct 20, 2016 | 10:58 AM
tony_2018's Avatar
Fish Twig
Ooooohhh...there does seem to be multiple camshafts for both intake and exhaust. This is interesting.
Old Oct 20, 2016 | 11:11 AM
tony_2018's Avatar
Fish Twig
So for documentation sake
Manual b18c
Automatic b18c
Old Oct 20, 2016 | 03:19 PM
thewrai6th's Avatar
Manual b18c
Automatic b18c
Interesting find, where did you pull those part #s from?
Old Oct 20, 2016 | 04:06 PM
Hatchg's Avatar
so you seem to know the answer to your own question than so why ask? Your popcorn eating emoji tells me you were looking to start drama. thats what i hate about these forums, but hey, do what makes you happy
Old Oct 20, 2016 | 04:10 PM
wunfstgsr's Avatar
Loved
Community Favorite
http://asia.vtec.net/beystock/integra/art2/index.html
Old Oct 21, 2016 | 06:47 AM
tony_2018's Avatar
Fish Twig
Good stuff here
Japanese cars online catalogs
Old Oct 21, 2016 | 06:52 AM
tony_2018's Avatar
Fish Twig
Damn...the automatic totally robbed the gsr of some power.
tony_2018's Avatar
Fish Twig
Its called debate/discussion. No need to get your panties in a bunch.
Old Oct 21, 2016 | 09:03 AM
Hatchg's Avatar
ohhhh, i must have miss read said persons intentions. My apologies sir.
Old Oct 21, 2016 | 07:20 PM
wunfstgsr's Avatar
Loved
Community Favorite
​​​​​​​Yes the transmission and accsesories and ecu is the major diffrence, i do beleive reading someone measured the cam lobes and they were the same as manual.
Old Oct 24, 2016 | 11:04 AM
You need to read the thread carefully before judging some one. I want to know where the OP online store told him there is auto and manual cams. I been in the Honda games for a long time (I'm in my 40s). This is the first time I have ever heard automatic and manual cams. I hate to see a buyer (OP) get shafted. That's like some one telling a female you need headlight washer fluid.
Just to make you all happy. I'm running a JDM CTR cams with ITR piston in my fully built GS/VTEC Automatic (JDM SIR-G) on a chip JDM P30 ECU tune on Neptune.
I have built a B20/VTEC (GSR head) on Hondata. I also have built a 454 on supercharge w/blower in my old Nova with a 4speed manual and a 502 for my cousin El Camino.
Old Oct 24, 2016 | 09:07 PM
wunfstgsr's Avatar
Loved
Community Favorite
Old Oct 28, 2016 | 01:12 PM
Hatchg's Avatar
impressive. to answer your question, hmotorsonline sold me the motor and told me of this difference beetween the cams. Actually a few other motor importers that sell b18c gsr's put the word AUTO in the description when listing a motor for sale if it is from an automatic model. You will find this if you look for gsr motors on ebay. You are 100% correct in that there is usually no difference in the motor if its auto or manual, but Why would they feel the need to list it is auto if there is no difference in the motor. I am not claiming to know for fact but each importer that i asked claimed that the auto version has different lift duration. I am sure you know very much and no ones judging anyone. You learn more everyday and therefore you never know it all. Keep an open mind
Old Nov 1, 2016 | 05:47 AM
tony_2018's Avatar
Fish Twig
I think the only remedy is to do a b20/vtec, LOL.
Old Nov 15, 2016 | 03:48 PM
Hatchg's Avatar
You are correct, just clarified with steve from hmotorsonline. I ordered a gsr head(specifically asked for one from an auto model) to use for my leftover b18b, since i will be replacing cams anyway. I will post pics of measurments when i get a chance, but they are the same size cam lobes.
