Gsr swap high idle
Old Oct 3, 2016 | 12:17 PM
Goobergobbler's Avatar
Default Gsr swap high idle
I finally got my swap started and it's doing a number of things when it's cold it takes a good minute to get it to finally idle. When it does it surges between 800-3000 rpm. When it starts to warm up it pretty much steady idles at 2500-3000 Rpm. I've tried checking for vacuum leaks by spraying brake parts cleaner around the lines and where the intake meets the head but nothing happend. I blocked the throttle body with a piece of wood while it was running and the motor died. There was a hissing noise Under the intake and I could feel the pressure slowly relieving in the intake. Also when I unplugged th iacv it dropped down between 1000-1500 rpm but it was surging.
Old Oct 3, 2016 | 03:15 PM
netfreak's Avatar
Default Re: Gsr swap high idle
I just did my own GSR swap and had endless idle/surging issues. I bypassed the FITV which helped a bit, cleaned the IACV which didn't seem to make any difference at all, then on a whim I replaced the throttle body with a different TPS and idles just fine now. Basically check everything then also make sure you've got no air gaps in your cooling.
Goobergobbler
Oct 3, 2016 12:17 PM
GP CR-V
Honda CR-V & Element
Nov 30, 2013 05:00 PM
builtsinglecam
Apr 27, 2009 06:10 PM
rwcdrums
Aug 1, 2007 05:59 AM
Midori Green
Jan 3, 2007 03:13 PM
