can't figure out this noise after head gasket
just finished replacing the head gasket today on a f22b2 and we are having a noise that sounds like its rubbing. it increases with the throttle, it makes the noise over on the cam side. the noise continues with the power steering and alternator belt off. was wondering if anyone may know what this is before i start taking off the plastic cam cover again. i think it may be a small plastic piece that was between the cam gear and where the cam is bolted onto the cam itself.
check out the video i attached.
never tried attaching a video before, hope it works
the lower, smaller belt ended up being to tight.
new issue,
we loosened the lower belt, and turned the motor over with the alt and ps pump out of the way, she turned over fine. but as soon as we put everything back together it won't run.
i will post a video here shortly
new issue,
civic_tuned
Apr 8, 2008 05:03 PM
