Suspension & Brakes Theory, alignment, spring rates....
ABS Light On
Old Oct 1, 2016 | 04:10 PM
H22 CB's Avatar
Default ABS Light On
My car recently got rear ended and pushed into the car in front of me...kept the car, but now salvaged. Getting it registered again is a b!tch. I need to pass a brake and light inspection and an ABS light is an automatic failure. When I jump the diag port and turn the key on. I get a single quick flash of the ABS light, then nothing again until I turn off the ignition and turn it back on. I would think the code would repeat. Anyway, I assumed it was a code 1 and attempted to bleed the ABS since it was drained (but not run) due to the accident. A low pressure hose had been severed. When I jump the ABS relay to run the pump, it turns on but doesn't move any fluid. What's wrong here?
newhondaowner29
Jan 11, 2006 08:11 PM
f22suzuka
Apr 21, 2004 10:15 AM
Undercover_Skank
Mar 15, 2004 07:13 AM
GSblueRacing
May 6, 2003 09:21 PM
CNSK
Apr 12, 2003 11:13 PM
