Gauge cluster not working after fuel pump change
ok so I changed my fuel pump in my 94 civic ex then it blew the fuse to fuel so I changed the fuse and it burnt the ground to the fuel pump. Since fixing that my gauge cluster stoped working all together. I've checked all the fuses multiple times now just kindve lost. I reground all the wires I could find.
Ok so I went back using different diagram for fire order n found that there was no fuse in the stop for the cluster. So I must've changed it and stuck it in wrong spot last time. Also found my dash light fuse was bad changed it. Now I have turn signals and all of my cluster but the speedometer still isn't working. I did put a trans out of a 99 into the car the plug is plugged in but not reading it. Is it possible that the obd2 sensor doesn't work with my Ecu? Since my car is odb1
Since my cel is working I ran the codes n pulling the VSS code I checked the plug it's plugged in good and snug. Going to look at the wires and see if they are bad.
Since the car was auto before that could be the reason it's not reading. I also pulled code 30 a/t
when I got the car there was no trans and no info just free with title and Ecu wireharness and blown engine
Endless
Nov 17, 2002 09:44 PM
