Sheared Axle ***Needs Feedback STAT***
Okay fellas, I would really appreciate some input/feedback in real-time if possible? First, have ANY of you sheared an axle or broken an axle and if so which side? How did you fix it? etc...etc... My particular situation is on the driver's side which on a 5sp connects to the intermediate shaft and then into the trans. Well my problem is that the splined portion of the axle which connects INTO the intermediate shaft has sheared completely off INSIDE the intermediate shaft. Now, for those of you familiar with these specific parts, the splined portion which is stuck in the IM-shaft has a snap ring on the end so it's not the kind of thing I can just grab with pliers and yank it out. As far as I can tell there's no damage to the IM shaft so I'd like to avoid replacing it if at all possible, Plus NOBODY keeps those in stock... Axles, all day, at just about every parts store, but the IM shaft.... Forget about it. So my big question is how should I go about pulling this piece out of the IM shaft? Any/all input and/or feedback will be greatly appreciated and THANK YOU in advance to anyone that can offer up some help. (Don't mind my cheapo oil filter... it's temporary)
Yank the intermediate shaft and stick it in a vise.
Center of the axle is usually softer than the outer shell.
Drill and tap the busted stub to allow for a large/long enough bolt to yank the stub out.
Careful when tapping, the hardness of the axle will vary the closer you get to the outer surface, fairly easy to snap a tap.
I've had the outer stub snap off, root cause is from the axle left to dangle(with no support). Weight of the axle will stress the base of where the stub attaches to the CV cup.
Or stop doing Bionic Clutch Dumps.
I do have one and this was going to be my absolute last resort just because of the whole HEAT thing, the piece that broke off was already twisted pretty tightly inside the half-shaft and I was concerned that if I over-heated it and warped it, even a little bit, that it may have become wedged in there permanently!? Good idea though...Thx for the reply
This is so true... But all the "u-pull-it's" around my way have the cars elevated and without a pretty badass cordless impact gun (Snap-on for example) there no way you're getting the axle nut off with the wheels in the air...? At least that was my thought? I don't know any tricks to immobilize the axle in order to crack the nut with a breaker bar other than having the wheels down? If you know one plz lmk though, because I will be on the hunt soon for some Prelude axles and half-shaft ( I hear they can handle a ish-LOAD of torque). Thx for the reply
I FKN LOVE YOU MANNY!!!! THANK YOU!
If you decide you need new axles and intermediate shaft, PM me, I have a Prelude intermediate shaft and matching CV shafts, good used condition, the shafts are OE Honda (not aftermarket).
