ABS codes 15 and 16
Old Sep 26, 2016 | 11:44 AM
br3k's Avatar
Default ABS codes 15 and 16
I have 2002 Accord LX that shows ABS codes 15, 16 (and 61 FWIW), at the same time. Replaced right rear wheel sensor, reset the codes (using the pin jumper/brake procedure), and they came back shortly on the next drive.
What's the best way to troubleshoot this? Is this wiring? If so - how do I test it?
Old Sep 26, 2016 | 05:29 PM
br3k's Avatar
Default Re: ABS codes 15 and 16
Crickets...
Old Sep 27, 2016 | 12:20 AM
holmesnmanny's Avatar
I would look towards the wheel bearing for any play. The bearing could be bad and that could cause it to throw a code.
Old Sep 27, 2016 | 06:00 AM
br3k's Avatar
Interesting, didn't know bearing can affect ABS sensor. I actually took bearing off while replacing the sensor - looked good fwiw.
Old Sep 27, 2016 | 11:58 AM
br3k's Avatar
Ok, got a bit further. I checked resistance from the connector side towards modulator. On the front sensorts it's about 7Kohm. On the rear sensor it measured 15Kohm, then 150Kohm, then when I moved the wire around a bit - infinity (i.e. no connection). So looks like there is a broken wire, most likely somewhere in the portion going from the grommet in the bottom to the connector.
Now - how do I fix that? That wire seems to be a direct part of wire harness, isn't it? Is there a way to access that location from inside the car? How do I get to it - seems to be somewhere under the rear seat? And where can I get replacement wire + female connector? Would really appreciate some advice.
Old Sep 27, 2016 | 10:55 PM
Best thing to do is to use a tone generator tool to put tone on the wire, then use the tone finder to find where it's open. The tool is about $30 or so. Then just put a butt connector on the open to connect it through.
John Haggerty
Honda Civic (2006 - 2015)
Feb 8, 2014 02:56 PM
chazt
Honda CR-V & Element
Apr 16, 2013 01:04 PM
maxogsr
May 26, 2005 11:09 AM
kmcmpb11
Oct 12, 2004 08:47 AM
FK00GSR
Apr 25, 2004 04:09 PM
