really need an experts help
Old Sep 25, 2016 | 04:46 PM
03civy's Avatar
Default really need an experts help
Hey guys I recently bought a 99 accord 4 cylinder automatic with a bad engine. I replaced engine with a known good one. No cel's or anything like that. However when I start it up when it's cold and put it in reverse or drive and touch the gas pedal it tries to stall unless I play with the pedal. If it's in park or nuetral it revs fine but as soon as it's in gear and cold it tries to die when on the gas pedal. It doesn't do this when it is warmed up and at operating temperature. Isles around 740-800 rpm. I'm just lost and don't know where to start with no cel. Any and all help is appreciated
Old Sep 25, 2016 | 07:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: really need an experts help
Did you reuse the intake/exhaust and sensors from the original engine?
Old Sep 26, 2016 | 02:49 AM
03civy's Avatar
no sir. Injectors and sensors I didnt change
Old Sep 26, 2016 | 06:31 AM
03civy's Avatar
I did reuse the original tb so it does have the original tps and map sensors
Old Sep 27, 2016 | 12:03 PM
MAD_MIKE's Avatar
MM Gruppe B
Is the IAC functioning?
Old Sep 27, 2016 | 12:13 PM
SIR-G Amp's Avatar
Idles around 740-800rpm when it's cold? Yeah, check IACV function.
-Amp
Old Sep 27, 2016 | 01:50 PM
03civy's Avatar
I'm sorry I misinformed you its idling 700-800 warmed up a little over 1000 when its cold
1999HondaAccord
Jul 20, 2011 05:35 AM
umair
Mar 2, 2009 05:08 PM
accordf22vtec
Apr 6, 2008 11:52 AM
Rex_Ryder
11
Apr 1, 2005 02:48 PM
rayweipu
Nov 18, 2002 09:59 PM
