Whats a sure way of me knowing if my timing belt has been changed??
Old Nov 8, 2002 | 10:21 AM
armharm's Avatar
Default Whats a sure way of me knowing if my timing belt has been changed??
when i bought my car in march the guy i bought it from said he changed the timing belt.... is there anyway i can check to see if it has been changed?
Old Nov 8, 2002 | 10:26 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Whats a sure way of me knowing if my timing belt has been changed?? (armharm)
make sure it's bolted on
Old Nov 8, 2002 | 10:51 AM
armharm's Avatar
Default Re: Whats a sure way of me knowing if my timing belt has been changed?? (Boosted97Lude)
**** you...lol
Old Nov 8, 2002 | 11:10 AM
prelude1897's Avatar
There really is no way of telling. If you're worried about it, just change it out with a new one
Old Nov 8, 2002 | 11:25 AM
PrecisionH23a's Avatar
Default Re: Whats a sure way of me knowing if my timing belt has been changed?? (prelude1897)
inspect the timing belt for any signs of wear. This includes both the smooth surface on the outside as well as the inside of the belt. if the ribs on the belt dont show alot of wear, you should be ok. if the car is going on 60k. if the car has been maintained through honda, then they should be able to pull up the service record in their database.
Old Nov 8, 2002 | 01:43 PM
armharm's Avatar
Default Re: Whats a sure way of me knowing if my timing belt has been changed?? (GudeH23a)
ok i'll try calling honda.. but i doubt the last owner had honda do any work because i have an aftermarket radiator... but then again he sold me his car as soon as his extended warranty expired..
Old Nov 8, 2002 | 02:05 PM
kevie88's Avatar
The sure fire way to tell it's been changed is to change it.. I just did them on both my motors, just because I couldn't verify them being done. When in doubt, just do it.
Old Nov 8, 2002 | 02:14 PM
armharm's Avatar
Default Re: Whats a sure way of me knowing if my timing belt has been changed?? (kevie88)
how much is it to change?
Old Nov 8, 2002 | 02:15 PM
visual's Avatar
ara, michaela kaif a ara! so
so we're not going today huh? at their site it says :
November 8th 2002
Friday
Canceled Due To Rain!!
Friday Night Grudge
Trophy & Time Only $15 Car & Driver
Run What Ya Brung - Open To All
Gate Opens at 5PM
Racing From 5:30PM to 10PM
Spectators and Crew $5 each
Old Nov 8, 2002 | 02:20 PM
kevie88's Avatar
Default Re: Whats a sure way of me knowing if my timing belt has been changed?? (visualvb)
huh?
I just changed them myself, I'm pretty comfortable with this stuff. I had to make a crank holder tool but that was pretty much the only hangup.. the belt cost me around 50 bucks US.
Old Nov 8, 2002 | 02:36 PM
armharm's Avatar
huh?
eh... i'm not a mechanic and i dont know if i should take on the task of changing my own timing belt...i watched someone do it once and it DID NOT look easy..
Old Nov 8, 2002 | 02:57 PM
jc836's Avatar
Dealer charges around $350 to start with. They also change the water pump, which is actually a very good idea.
Comp97GSR
Dec 30, 2022 12:10 PM
Stealthman80
Oct 25, 2005 09:12 PM
Fink2iCe
Oct 6, 2004 09:23 PM
omeara7
Jul 8, 2004 07:12 AM
itr980923
Oct 2, 2001 11:27 PM
