opinion on exhaust manifold
hello,
new to honda tech, so i may not know what im doing, but im looking for some advice/opinions.
Ive got an ek hatch with a type r B16B, and im in need of a new header and midpipe with better ground clearence, as well as fits up to my pre-existing CTR axle back, and my stock ITR Cat.
I was planning on getting an B18B1 LS header, but i wasnt sure if it'd fit up to the cat, bc ive heard their flanges are at different angles.
Also, what mid pipe would have the best ground clearence? ive been looking for an EM1 mid pipe bc only coupe b series will fit my hatch, so ive been told.
*note* my ITR 4-1 is currently sitting a half inch off the ground, which is why im looking for the best ground clearance. Any and all advice will be appreciated!
Thanks!
Thanks!
MM&Y of car along with trim level and any/all mods, with out that info all I can suggest is raise the car, problem solved.
I autocross my 94 RS and slam it when on the track but raise it to a "drivable" height when on the street.
Are you looking for OEM Honda/Acura or aftermarket? 94
RICHJ
Feb 28, 2002 10:33 AM
