97 civic/b16a2 swap - speedo doesn't work
Old Sep 16, 2016 | 04:47 PM
DohcVtec77's Avatar
Default 97 civic/b16a2 swap - speedo doesn't work
hi there as the title states I have a 97 ex with a b16a2 from a 2000 si. The speedo and odomotor do not work. My vtec works fine as well as all my other guages. I DO NOT have a check engine light and vtec works so I don't believe it's the VSS. Any input would be greatly appreciated thanks!
Old Sep 16, 2016 | 07:47 PM
tony_2018's Avatar
Fish Twig
Default re: 97 civic/b16a2 swap - speedo doesn't work
What ecu?
Old Sep 17, 2016 | 06:18 AM
Former User's Avatar
Default Re: 97 civic/b16a2 swap - speedo doesn't work
This^
But...does the CEL work?
Old Sep 17, 2016 | 07:02 AM
spAdam's Avatar
Loved
Community Favorite
New problem on an old swap or new swap? If new swap, is there a cheapo adapter harness involved?
Old Sep 17, 2016 | 11:11 AM
DohcVtec77's Avatar
B16a2 motor and trans p72 gsr obd1
Old Sep 17, 2016 | 11:12 AM
DohcVtec77's Avatar
Originally Posted by RonJ
This^
CEL works fine old swap before I got it, I unplugged the VSS in the trans and it threw code 10 but when I plug it back in CEL goes away
Old Sep 17, 2016 | 11:14 AM
Looks^ like you have sensor connectors swapped. And you're also using the wrong ECU.
Old Sep 17, 2016 | 11:38 AM
DohcVtec77's Avatar
P72 can't be used with a b16? I have the harness to convert it to obd1 and how would I go about changing those sensors?
Old Sep 17, 2016 | 11:40 AM
Don't replace any sensors. Instead, check whether you mismatched connectors to some sensors.
You can do anything you want, but the ECU is not a match for the engine.
Old Sep 18, 2016 | 08:31 AM
DohcVtec77's Avatar
I'll give it a go
Old Sep 18, 2016 | 12:01 PM
DohcVtec77's Avatar
so what are the color combinations of the wires to make sure I have the right one
DohcVtec77
Mar 13, 2016 03:29 PM
Jcd5
Jun 13, 2014 06:58 AM
BJM3x96813
Apr 14, 2014 04:57 AM
hookahpro
Apr 13, 2013 11:16 AM
