D16Y8 - Where does the crank pulley timing mark line up?
Old Sep 15, 2016 | 03:51 PM
joshuad86's Avatar
Default D16Y8 - Where does the crank pulley timing mark line up?
after a few months I have the free time to take another look at my car which is 92 hatchback with D16y8 has z6 intake manifold and p28 ecu.. car starts idles fine and smooth then dies.. I have tools on way to test fuel pressure but I decided to take a look at the timing marks not sure where the red or white mark on crank pulley are suppose to line up
Old Sep 15, 2016 | 04:02 PM
Former User's Avatar
Default re: D16Y8 - Where does the crank pulley timing mark line up?
You can't use the crank pulley timing mark without the lower timing belt cover installed.
For the cam, use the timing marks on the rear side of the pulley to score alignment with the top of the head.
Old Sep 15, 2016 | 04:13 PM
joshuad86's Avatar
lower timing cover didn't come with car... would find a timing light to check and confirm ignition timing but cant get it to run long enough
Old Sep 15, 2016 | 04:14 PM
Get a lower timing belt cover from a junk yard.
Old Sep 15, 2016 | 04:24 PM
joshuad86's Avatar
are all sohc lower timing covers the same or does it have to be y8 specific? its kinda rare picking for Hondas in junkyards around here
Old Sep 15, 2016 | 04:27 PM
no
Old Sep 15, 2016 | 05:16 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You can check your mechanical timing without the lower cover but not the ignition timing (requires engine running to operating temperature and the lower timing belt cover).
The following page is for both the D16Y7 and the D16Y8 motors for the mechanical timing marks. You will have to pull the crank pulley off to see the crank gear and it's alignment.
You can then use OEM Honda parts sites like hondapartsnow.com to compare the lower timing covers between the two 6th gen engines (D16Y7 and D16Y8). I know the D16Y7 is a much more common engine in the yards.
As can be seen below, the lower timing belt cover is the same between the D16Y7 and the D16Y8 engine (DX vs EX). I verified by looking also at the cylinder head on each car and noted the DX is non VTEC while the EX was the SOHC VTEC motor:
Size:  56.2 KBName:  Capture2.JPG
You can go grab yourself the lower timing cover from any 96-00 CX/DX/LX from the yards.
Cheers.
Old Sep 16, 2016 | 07:06 AM
mk378's Avatar
You can take the #1 spark plug out and probe the top of the piston to set the crank to TDC, and at least get the cam right. But you really must have a cover in case a stone from the road or anything jumps into the timing belt while it is running that would blow the engine.
Old Sep 17, 2016 | 10:41 AM
joshuad86's Avatar
Default Re: D16Y8 - Where does the crank pulley timing mark line up?
Got a fuel pressure gauge today.. On prime makes 110 psi and almost 114psi when running until it dies
Old Sep 17, 2016 | 10:46 AM
Isn't it reading 13.8 PSI (=low fuel pressure) on the gauge in the picture? You also need a fuel gauge that reads higher pressure.
And your mechanical timing may be off, as stated earlier.
Old Sep 17, 2016 | 11:38 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
^^^This concerning the fuel pressure gauge you have. You need a fuel injection pressure tester, what you have is for the old carb based engines as they only needed 12-15 PSI pressure unlike fuel injected motors.
Please follow RonJ's hints and provide feedback on them to help you isolate your issue.
Old Sep 17, 2016 | 01:58 PM
joshuad86's Avatar
Yes I know now sorry for the dyslexia I ran and got a pump car starts and runs.. Idles still fluctuates a very small amount after small revs
DavidCRV
Aug 26, 2013 03:12 PM
Civic-Kids
Mar 12, 2009 01:45 PM
94dxt
Oct 27, 2004 12:36 PM
boostedcvc
Dec 22, 2003 10:24 AM
JONBLAZE55555
Nov 27, 2003 09:09 AM
