96 Civic Coupe EX/HX Door Wire Harness differences
I need some help, the dealership didn't have a clue of the differences between a 1996 Civic Coupe HX Driver's door wiring harness and a 1996 Civic Coupe EX driver's door wiring harness. I don't expect everyone to do my own work for me. I have looked and the only thing I can see that is different between the HX and EX is that the EX has tweeters in the panel by the outside power mirror. The rest looks like it's identical.
When I look at the HX's price for the wiring harness is ridiculous, but the EX is much more affordable. I haven't done the work yet, but some mechanic in the past messed up the wiring inside the door and it might be easier just to drop a new door harness in than trying to de-pin all day, etc.
Here's the two part numbers.. EX is 32751-S03-A20 and the HX is 32751-S03-A10. If anyone knows the differences, I'd really like to know.
When I compared the HX and EX coupe door harnesses, all my info only shows that the EX difference was the extra tweeter speaker in the door. But the difference in price is insane! The HX is $700+ and the EX is about $60. So I'm trying to figure out why the price difference, what is so different. I can't find anything in the service manual.
The one thing I would look at are the part numbers of the power window motor and the door lock motor. If they are diff between both models than yeah it could possibly be diff.
Majestic Honda shows the 96 HX coupe harness as discontinued. I think the 96 EX coupe harness would have a high chance of working in a 96 HX coupe.
You can probably get it cheaper at a pull a part. Just take your time and pull what you need. I love going to a pull a part.
Pliers, flat head screw driver (all sorts). 10mm(probably), philips screw driver(all sorts).
thanks for the info on the tools that I'll need for a pull-a-part junkyard. I'll see what's available around my area, but what's nice is I know that the harness is available in case I can't find what I need. Just nice to have a back up plan.
The only difference should be the tweeter leads and they just run parallel from the woofer/midrange lead, [connected at the terminals to for the woofer/midrange] other then that they should be the same.
FYI the most common problem with a drivers door harness, [any car] is broken leads in the door boot, between door and chassis, because the drivers door is opened and closed 100s of times more then any other door the wires inside the boot will brake they may even still look OK but the wire strands inside the insulation are broken but the insulation is still intact, most often leading to intermittent operation of some functions, [if opening or closing the door makes a difference then that is the problem].
Also any repairs to those broken leads done in the boot will not last long, so a new door harness is the best way to go or at the very least a new plug and pigtails long enough to reach into the door so connections can be made inside the door instead of in the boot. 94
You are correct, the tweeter wiring is the only difference.
However my hx had the tweeter wiring in the drivers side door, but the passengers side did not have the wiring. So I went to the junk yard and got 2 tweeters for $10 and only one had the wiring. Not sure if that was stock or not, my drivers side was pretty heavily molested
Yep that is "heavily molested" and not a proper repair, a door is not weatherproof those connections should all have been soldered and shrink tubed and staggered, [connections not all in the same spot] ,
For the OP, sad to see you have no PicknPull lots in Michigan closest is in Summit or Hammond IN or in Columbus OH, 94
Yeah I found conflicting information about the door tweeter wiring, most people with an hx and lx said they had the plug already there in the harness and they just had to hook it up for the tweeter to work, but mine was missing the wiring and plug on the passengers side
As long as the harness is for a 1996-98 car you will be good. If you need to re run wires click on my user name to see the threads ive started and you'll find a thread where I had to re wire and trouble shoot wiring from that drivers side door to get the door locks working again
And yeah the part number I did find was for a 96 ex 2 door, driver's side, luckily no one screwed with the passenger side (won't need it) because that part is discontinued.I'll have to re-run some of the wires from the cabin to the door, and I'll check on some of your threads!! Thanks, I appreciate the help! I kind of thought you might know a little about the HX's since you have gone through a lot of them! cool.. so now I just need the time to work on it! lol
Direct link to rons post with the door wiring pinout. My problem was power supply, so dis regard my posts about anything else being the problem
https://honda-tech.com/forums/honda-.../#post50170394
lustworld
10
Sep 3, 2015 08:15 PM
lustworld
12
Jul 23, 2015 07:22 AM
