'94 Civic - Can I drive without Power Steering fluid?
Old Sep 6, 2016 | 12:23 PM
Plasma1010's Avatar
Default '94 Civic - Can I drive without Power Steering fluid?
I was wondering, since I have a PS leak if I can just drive without the fluid and not have power steering ? What bad affects could occur if any ?
Old Sep 6, 2016 | 12:30 PM
Former User's Avatar
Default re: '94 Civic - Can I drive without Power Steering fluid?
Can you? yes
Should you? no
Old Sep 6, 2016 | 01:00 PM
Plasma1010's Avatar
Default Re: '94 Civic without Power Steering
Originally Posted by RonJ
Can you? yes
Should you? no
I guess the pump can dry out and stop the serpentine belt. Any alternatives to fixing a pricey leak ?
Old Sep 6, 2016 | 01:03 PM
Default Re: '94 Civic - Can I drive without Power Steering fluid?
Where's the leak?
Old Sep 6, 2016 | 01:07 PM
Plasma1010's Avatar
Underneath
Old Sep 6, 2016 | 01:09 PM
Haha...Can you be more precise? Otherwise, buy and install a manual gearbox and live fluid free.
Old Sep 6, 2016 | 03:27 PM
Plasma1010's Avatar
The assembly underneath needs to be replaced if I keep power steering, would it be more cost effective to install a manual gear box or do what this guy did and rotate the fluid in the rack alone ? Or am I mistaken and they are one in the same thing ? I have an Automatic by the way.
Old Sep 6, 2016 | 03:30 PM
You're asking the same question again. To get an intelligent answer, you must pinpoint the leak site. For example, if fluid is leaking from the one or both boots, you must replace the steering rack (gearbox).
Old Sep 6, 2016 | 03:31 PM
HondaTechMan121's Avatar
So the power steering Rack is leaking? or one of the lines?
Old Sep 6, 2016 | 04:22 PM
Plasma1010's Avatar
It's the rack.
Old Sep 6, 2016 | 05:11 PM
Which part of the rack? Please don't answer because I know you won't. Answering your question requires knowing the leak site. I think you can take it from here.
Thread locked.
stevevang
Nov 2, 2015 03:47 PM
Axatax
Sep 28, 2013 01:56 AM
dan_g
Dec 27, 2011 08:49 PM
vtec.dc2
Aug 1, 2006 08:16 AM
