Broken flywheel bolts
Old Sep 5, 2016 | 08:25 PM
scrubdakiller80's Avatar
Default Broken flywheel bolts
My 96 accord has like 5 or 6 broken flywheel bolts the fly wheel is no longer attached to the engine but the bolts are still stuck in the engine they recommend that I swapped the engine or replace the crank but I don't have the money for that so I was thinking if it was possible to take the bolts off some how not really trying to spend 1200 on it yet let me know asap I'll post some pics when I see it again
Old Sep 5, 2016 | 11:08 PM
holmesnmanny's Avatar
Default Re: Broken flywheel bolts
You will have to use a bolt extractor on them. Someone must have used the red threadlock on them instead of the blue. Basically you have to drill into the middle. Then hammer the bolt extractor in, then turn the bolt out and it will pull the flywheel bolts out since the bolt extractor is reverse threaded so turning it out will push it in, but it will pull the flywheel bolts out.
It would be best to call around and find an experienced mechanic who has used them before.
Old Sep 6, 2016 | 03:59 AM
kr3w108's Avatar
You can weld a bolt or nut to the end of the broken stud and turn it using a wrench.
Old Sep 7, 2016 | 12:38 PM
MAD_MIKE's Avatar
MM Gruppe B
If loctite was used, before trying to extract anything, get a small MAP torch and heat up each bolt til its about ~500°F/260°C to release the loctite. Otherwise you are just going to be breaking extractors. You might be able to remove the busted ends with just a punch after you have broken the loctite bond.
Don't forget to replace the rear main seal when you are done, as that much heat is not going to be good for it.
Old Sep 21, 2016 | 09:17 PM
The flywheel is on the tranny instead of the engine all the bolts broke its not fixable the crank is fucked
Old Sep 22, 2016 | 09:10 PM
MAD_MIKE's Avatar
MM Gruppe B
I would really be interested in how this came about.
Old Sep 23, 2016 | 04:56 AM
Originally Posted by MAD_MIKE
https://www.youtube.com/watch?v=ETN9eNOA6vw
The previous owner did a f23a1 swap on it he must have not tighten the bolts enough but the major problem was the tranny 1st or 3rd didn't work do it had to no driven in 2nd and it was my first manual so the clutch was completely destroyed too
eh2_Trav
Transmission & Drivetrain
Nov 4, 2016 08:47 AM
c0d0r
Mar 29, 2009 02:22 PM
MisterB
Sep 10, 2003 11:24 PM
Specialk
May 21, 2003 02:14 PM
giooooo
Feb 6, 2003 08:25 PM
