Function7 subframe asr rear sway bar with brackets
I've searched with no prevail. Read a thread that function7 said it is possible. Want to see if anyone has any pics before I buy the asr rear sway bar. The 25 mm with d brackets. Would like to avoid using energy suspension. Thanks.
I think you me "I've searched to no avail".
It's a swaybar, they are all the same. If the brackets will bolt to a stock subframe they will bolt to the ASR brace as it uses the same mounting locations.
I am a Function 7 distributor, I have plenty of clients including myself who have used the ASR on the Function 7 brace. What seems to be the issue?
You need a swaybar, I got a 24mm that will work, with brackets.
Mikes2000civicsi
Mar 27, 2008 09:02 PM
JunY
34
Feb 9, 2006 04:43 PM
