00 Civic EX died while on highway
Old Sep 4, 2016 | 08:04 PM
mimog3's Avatar
10 Year Member
Default 00 Civic EX died while on highway
hi everyone, I have a 2000 civic ex that decided today wasn't the day to stay running. I decided to push the car today doing about 100 mph, then I felt the car losing power. I pulled to the side of the road and the car died. As soon as the car died the check engine light came on, it came on for a p0108 which is the map sensor. I replaced that and the car didn't start, then replaced the ignition coil because I didn't see spark, after replacing the coil I saw spark, but the car still won't start. I checked all the fuses and they are still good. I checked the camshaft and it's turning, I checked the belt and it hasn't snapped. I checked the fuel pump from the back to the front of the engine, fuel is pumping. At this point I'm completely lost. What do I do people? Any help is appreciated.
Old Sep 4, 2016 | 08:34 PM
Former User's Avatar
Default re: 00 Civic EX died while on highway
Bone stock 00 Civic EX?
Reset the ECU and then crank the engine for 30 seconds. Any CEL codes thrown?
Check the mechanical timing. If fine, compression test the cylinders.
Old Sep 5, 2016 | 06:53 AM
tony_2018's Avatar
Fish Twig
Old Sep 5, 2016 | 07:18 PM
mimog3's Avatar
10 Year Member
Default Re: 00 Civic EX died while on highway
Stock for the most part for the exception of a cold air intake that has sucked up small amounts of water here and there causing small misfires. I am assuming this may be the cause for low compression in the engine which I found out earlier today. Here are the number for each cylinder. 4 :130 3: 130 2: 95: 70
Old Sep 5, 2016 | 07:21 PM
Do a cylinder leakdown test to determine where compression is lost.
The water may have destroyed the engine.
Old Sep 5, 2016 | 07:43 PM
mimog3's Avatar
10 Year Member
Will do, thanks for the help Ron
Hondaman4life66
Apr 6, 2018 05:30 AM
CivicGuy2014
Mar 24, 2014 10:05 AM
ocelotz17
Jul 7, 2010 12:43 PM
96redexcivic
Honda Civic (2001 - 2005)
Jan 24, 2010 02:41 PM
vorovsky
16
Aug 3, 2003 12:59 PM
