Bad idle when hot on basemap
Old Sep 3, 2016 | 04:46 AM
Stevieh62000's Avatar
Default Bad idle when hot on basemap
Hi, Ive recently done a swap from a b16 to a b18. Im using a basemap chip currently. Once the engine is up to temperature and the car is stationary at idle the revs drop and sometimes cuts out.
Ive calibrated the tps and ive swapped the idle control valve from the b16 as i know that works. Ive also wound the air screw out but has made no difference.
What can i do about this? My setup is pretty standard so surely a basemap would run it pretty well?
Any advise greatly appreciated
Old Sep 3, 2016 | 09:06 AM
thewood1988's Avatar
Default Re: Bad idle when hot on basemap
So, on a cold start it idles fine? Could be a few different things...
Old Sep 3, 2016 | 01:17 PM
Like? Yes idles ok when cold.. I'm thinking maybe the timing on the dizzy is off..
Old Sep 4, 2016 | 02:01 AM
I fixed this this morning.
I swapped the injectors and regulator from the old b16 just to rule them out and I also advanced the ignition 2deg.
Idles fine now and goes much better.
People say all b series injectors are the same but there was clear differences between them. The tips on the b18 ones were yellow and on the b16 they were brown and a different shape.
Gonna be hard not to floor it now before getting it mapped!
CRX30436
Apr 24, 2008 09:44 PM
miniorf
Feb 9, 2006 10:48 AM
jarvis199
Sep 15, 2005 06:26 PM
EFin' Kyle
Sep 3, 2004 09:32 PM
