Rough Idle @ 2500 rpm and CEL code P0122 - Are all 92-00 Civic TPS sensors the same?
My engine start up is experiencing rough idle @ 2500 rpm. The check engine light is on and the code reads P0122, which is a Throttle Position Sensor/Switch A Circuit Low Input. So i'm pretty sure that my TPS is causing the rough idling. I've thought about the calibrating the throttle body, but considering how old the motor is and the shape of the TPS it is in, i figured i should try to at least replace it to make sure that i'm working with a brand new unmolested TPS and not a POS. But before i ordered myself a new one, i just wanted ask, is all 92-00 Honda TPS the same? I mean, like, are they interchangeable?
410ruga
Mar 25, 2014 12:07 AM
ludacole
Aug 13, 2005 11:59 PM
