98 Civic EX - No Start
Old Aug 30, 2016 | 04:52 PM
TNight's Avatar
Default 98 Civic EX - No Start
Sunday 1st day I drove the car in about a week I get about a a mile away from home and car dies. No evidence of anything wrong after about 10 min. of checking what I could w/ no tools it starts up . Drove it 15 miles or so away parked it for 3-4hrs started up drove it back home. Today my son started it and drove it around the block to park it in front of the house2 hrs later no start . I have checked the battery 12.37 check for codes P0141 for the catalytic converter which I know to be a bad connection but no other codes . Any suggestions Thanks in advance
Old Aug 30, 2016 | 05:07 PM
Former User's Avatar
Default re: 98 Civic EX - No Start
Check fuse 15.
https://honda-tech.com/forums/honda-...codes-3263199/
Old Aug 30, 2016 | 06:11 PM
TNight's Avatar
Fuse 15 was good
Old Aug 30, 2016 | 06:14 PM
By voltage test? Give details.
You never followed up on the 96 Civic thread? What happened?
Old Aug 30, 2016 | 11:58 PM
eghatch9295's Avatar
Stancetard Hate Monger
sounds very much like a coil issue, start there.
Old Sep 7, 2016 | 04:38 PM
TNight's Avatar
Ron J on the 96 got that figured out mea
nt to get back on and thank you So. Thank You
On this 98 the problem is intermittent . I changed the fuse because I had some it made no dif. Went out the next morning it started right up . Today no such luck ,can't really do to much right now as it has been pouring on and off all day. I am wondering if it could be a fuel pump or relay on the way out , so I am looking up ways to test them . Any techniques or ideas appreciated.
Old Sep 7, 2016 | 05:13 PM
Turn key from OFF to ON(II) [engine off]. Does the cluster charging system light turn on and stay on?
Also, when the engine won't start, check for spark and fuel.
Old Sep 8, 2016 | 06:29 AM
chrysler kid's Avatar
It sounds like a similar problem ron helped solve in another thread. Disconnect the primary oxygen sensor before you start the car and leave it un plugged. See if you can drive it around now without the car stalling and dying. You could have an exhaust crack before the primary oxygen sensor causing the catalyst code and giving the primary sensor incorrect temperature and air readings
Old Sep 16, 2016 | 07:32 AM
TNight's Avatar
Moved it once earlier this week no problem starting then this morning she refused Charging light stays on sprayed carb cleaner into the intake no help. Will check for spark and fuel when I get a second set of hands. or how would I check these w/o help
Old Sep 16, 2016 | 03:58 PM
TNight's Avatar
Went back a few hours later ready to tes and it starts up no problem wth
Old Sep 16, 2016 | 04:17 PM
Sounds like an ignition problem. Try replacing cap and rotor and spark plugs
Old Sep 16, 2016 | 09:39 PM
Old Oct 16, 2016 | 07:33 PM
TNight's Avatar
Default Re: 98 Civic EX - No Start
Ok since the last time I wrote about this issue the car has been running fine remembering that it sits 4-5 days at a time So I started it Mon. went to pool leagues and came home no problem again on Tue. just errands no problem Fri. Night out to play and home no problem .Rained pretty bad yesterday didnt go out ,then today needed to take my son home you guessed it NO START.Got Fuel Got Spark, Don't wanna just tstart throwing parts at it any other ideas?
BigJerm333
11
Jan 9, 2014 06:22 PM
patoloco008
Dec 7, 2013 06:25 AM
95F22B2
Mar 27, 2012 02:03 AM
MyExWasBrokenInto
Jan 25, 2006 06:58 PM
