hydrolocked, what should i do now?
mods. i posted this in the busiest forums hoping to get some help. please understand and let the thread run until enough help is given. i really appreciate it.
refer to http://honda-acura.net/forums/showth...threadid=32821 for the story.
i got it to run now. it runs like nothing happened. should i still change the plugs and oil and what not?
thanks.
thanks.
do the basic stuff, Oil, oil filter, Ck the Air filter, ck the valves,change the spark plugs and see if the TB got mucked up.
Seeing how you took the right reactions when you hit the last puddle Hopefully everything should be ok.
Goodluck.
Goodluck.
thanks. this was on a regular intake with a Injen extension.
i replaced the plugs already, and will change the oil when i get the chance. the car is running fine now.
if by any chance could i have broken something, when though the car is running ok? im scared i might have cracked a rod or something. should i take my oil pan out and check?
thanks.
thanks.
thanks.
thanks.
if you haven't checked the oil, do so now. If it has water in it, CHANGE it now, regardless of whether or not the car currently runs.
Just out of curosity, what would water in the oil do? Could it rust the cylinder walls?
hookedonvtec
15
Oct 13, 2004 01:12 PM
