Car cranks but no start
Old Aug 29, 2016 | 11:10 AM
tchandarlis's Avatar
Default Car cranks but no start
Blew head gasket, rebuilt head, new head gasket kit, timing is TDC, all bells and whistles connected, fuel pressure is good, distributor has spark. Car cranks but no start....... z6 head on a y7 block, vtec ported.
Last edited by tchandarlis; Aug 29, 2016 at 11:17 AM. Reason: Adding specs on motor
Old Aug 30, 2016 | 01:29 PM
fcm's Avatar
fcm
Old Fart
Default Re: Car cranks but no start
Have you done a compassion test, checked for spark with an HEI spark tester, checked to see if fuel is reaching the cylinders, are the spark plugs "wet" with gas after trying to start the engine?
You need a good spark, [using an HEI spark tester] a spark plug or screw driver to ground is not the correct way to test for proper spark, [operative word is "proper" spark]
Fuel pressure does not mean fuel is reaching the cylinders, there may be a restriction or the injectors are not pulsing, [try starting the engine then immediately remove the spark plugs checking to see if they are "wet" with fuel.
Once the plugs are all out check compression, open TB all the way and use a by-pass jump to crank engine, that way the coil will not fire and the injectors will not pulse.
How to do a bypass jump is explained in the sticky at top of page, simple DIY starter circuit test/bypass jump. 94
Old Aug 31, 2016 | 05:51 AM
Old Aug 31, 2016 | 05:55 AM
Ok.....timing is set....@TDC....went to tighten crank gear, belt doesn't turn, loosen from tensioner....
Old Sep 2, 2016 | 09:57 AM
fcm's Avatar
fcm
Old Fart
What does that mean???? 94
Old Sep 6, 2016 | 09:33 PM
D16 Minin Me's Avatar
Check for fuel,timing,cap n roter
bassamillion
Honda Civic (2001 - 2005)
Jun 20, 2018 05:55 AM
eldudepapi
Apr 20, 2017 12:00 PM
FlyingDaggers
Jan 30, 2008 06:19 PM
Lokisdope
Nov 21, 2007 06:26 PM
g2turbo
Sep 17, 2003 08:31 PM
