cant get freelog to work
I set up my Ostrich and Hulog yesterday. I'm using Crome Free and Freelog on a P28 ECU. J12 is cut. I don't have a wideband yet so Im not making any changes to the basemap just looking around the programs.
When I run Freelog it just gives random numbers for everything and I have no idea what to do with it
Any help>?
Any help>?
ECU Chipping Kit - Phearable.net
I did cut J12 which should have made it full duplex.
Maybe I have the data logging header in backwards?
It's possible, the headers orientation itself shouldn't matter, what matters is that whatevers plugged into it (hulog?) Is connected properly. I've never used a hulog, just a datalogging cable I made myself with an ftdI chip and stuff..
Have you tried connecting with crome? I haven't used crome in a while but the free version should have logging too? It was crome qd2 for free and qd3 for pro I believe, protocol-wise.
You should consider eCtune, pm me if you want to.
The Hulog seems to connect fine to the pc. Crome free doesn't have data logging. I tried downloading eCtune but every time I try to run it it says unable to find native library
Buitrex
Engine Management and Tuning
Feb 24, 2010 12:11 PM
