Wideband wiring for s300
Trying to wire up my innovative wideband to my s300 in a p28. Read mixed reviews about this wideband reading different then the s300. To use d14 for o2 and d10 for eld and stuff about removing resistors. I need a more steady answer.
I mostly use D10. if you plan to use D14, remove R136 and R138. Those resistors make a resistive divider and limiter, the input cannot read over ~3.8v
That is incorrect. I advise against using D14 as is does not read correctly as stated above. The resistor mentioned above must be removed if using D10 which is the recommended input to use.
Closed Loop Advanced Parameters
I have zero issues using d10 with the resistors removed, did this on two cars recently no problem.
Reads full 10 to 20 afr with my plx, whereas d14 won't read above 17.3 or so.
HondaHeddie
Dec 14, 2006 03:56 PM
Bailhatch
Feb 11, 2004 02:47 PM
