bought EJ6 with aftermarket upper control arms - need ball joints
Old Aug 24, 2016 | 12:40 PM
dazebreak's Avatar
Default bought EJ6 with aftermarket upper control arms - need ball joints
Can anyone tell me who makes these, I need to replace the ball joints. I bought the car with aftermarket coilovers, and upper control arms already installed. Where can I find the tool to adjust the springs on the coilovers?
Regular or OEM upper control arms wouldn't work because of the adjustment needed due to the coilovers, correct?
Thanks!
Old Aug 24, 2016 | 01:45 PM
White_EG1's Avatar
Default Re: bought EJ6 with aftermarket upper control arms - need ball joints
No, OEM works fine and I'd suggest that for longevity. The tool for the coilovers is called a spanner wrench and you can buy them anywhere online.
Old Aug 25, 2016 | 09:42 AM
dazebreak's Avatar
Spanner is just another word for wrench, but I guess you mean coilover spanner.
The only problem I see with using regular upper control arms is the ball joints are at the ends of the arms, while the ones I have now the ball joint is in a slotted track and can be loosened and moved to adjust camber.
I think maybe my camber will be off if I use normal upper control arms.
Old Aug 25, 2016 | 02:32 PM
White_EG1's Avatar
Well from what I know it's called a spanner.
Nothing a alignment can't fix
Old Aug 26, 2016 | 09:07 AM
dazebreak's Avatar
I guess that makes sense, the tie rod ends should have enough adjustment left. I guess I will find out.
Old Aug 28, 2016 | 05:00 AM
94EG8's Avatar
Seagull Management
Skunk2 sells replacement upper balljoints for their adjustable upper arms. I'm not sure if that's what you have, but from what I can see they look like Skunk2 upper control arms.
Old Sep 1, 2016 | 09:05 AM
dazebreak's Avatar
Thanks. They might be a knock-off, but the Skunk2 ball joints might fit anyway.
Old Sep 2, 2016 | 06:17 PM
slomofo's Avatar
GDD Member
Doesn't matter if knock off or not, Junk2 is made in the same place as the knock offs, so the likelihood of them fitting is pretty high.
kamikazie
10
Jan 10, 2013 08:44 PM
95civhb
May 28, 2008 08:32 AM
97elitehonda
Suspension & Brakes
May 7, 2007 10:06 AM
matt1982
Mar 17, 2007 09:45 AM
Teal5GenHatch
11
Jul 27, 2006 06:21 PM
