brake master cylinder stuck on brake booster
Old Aug 22, 2016 | 11:17 AM
trailblazer's Avatar
Default brake master cylinder stuck on brake booster
I'm replacing the master cylinder on my 1995 del Sol si, but can't get the old one off the brake booster. I already disconnected the lines and unbolted both 12mm bolts and tried to yank off the MC but only got a good wiggle going so far enough to see a small gap and spray wd40 in it (all I have) and tapped it with hammer wiggled and yanked it as much as I could..its old and was corroded together but feels like its stuck in the middle
also, I read with everything connected and bled, you can hit the brakes with the 12mm bolts loose and it will break the MC loose from the booster? . but even if u have a bad mc stuck on there?
Old Aug 22, 2016 | 11:56 AM
chrysler kid's Avatar
Default Re: brake master cylinder stuck on brake booster
Mine just slid off but it's a southern car. It should only be held onto the booster by two nuts and slide off. It sounds like yours is getting stuck on a thread of the booster.
Try something better than wd40 on rust, pb blaster is what you should try next
Old Aug 22, 2016 | 12:10 PM
Former User's Avatar
Old Aug 22, 2016 | 01:11 PM
slomofo's Avatar
GDD Member
This is going to sound really stupid, so stupid that it may actually work.
Go press the brake pedal down a few times. Did the master cylinder fall off on it's own?
If yes, then hooray for my stupid idea.
If no, then make certain everything is undone.
@TomCat39
Old Aug 22, 2016 | 01:26 PM
^worth a try
A rubber mallet may also help.
Old Aug 22, 2016 | 07:02 PM
I didn't try that with the lines connected yet, but im sure I would have to bleed them too. I already emptied the mc too. I don't know if I should reattach the lines bleed the system just to try to pump the brakes with the MC mounting nuts loose and brake it free. wondering If that works
also I tried a rubber mallet too, we can get it to wiggle with lots of force but it feels like its stuck inside somehow but it is corroded bad I can take pics tmrw in sunlight ill try to find pb blaster if I think I can yank it off but tried for a hour
Old Aug 23, 2016 | 03:40 AM
Well then remove the brake booster and take the whole thing apart once you get it off. If it's that bad you're probably going to need a new booster anyways
Old Aug 23, 2016 | 06:27 AM
yea the booster still works tho idk I'll try again now. I'll let young guys know thanks
Old Aug 23, 2016 | 07:16 AM
thanks I got my hands on some pb blaster and after a hour soak it came right off
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
ilvi3tkidxx
Oct 16, 2008 06:51 PM
mixmastabob
Dec 7, 2006 12:09 PM
Budddweiser
Oct 8, 2006 03:19 PM
Eggman
Oct 6, 2002 09:32 AM
