Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need Help ! Possible Bad Throw Out Bearing?
Old Aug 19, 2016 | 08:47 AM
Achroth's Avatar
Default Need Help ! Possible Bad Throw Out Bearing?
Alright guys I need some help.
Got my transmission fixed about a month ago and was told my clutch is going to out within 6 months but I didn't swap it out. After I got the car back from the shop I noticed this sound it seems like it's getting louder.
Doesn't happen when I press the clutch only when I start to release it and start pressing on the gas. Was curious if anybody knew if it was the tranny or the clutch since I have warranty I wanted to take it in but didn't want them telling me it's my clutch and not the tranny.
So I took it to the shop today, and at first they denied they even changed it. I told them it was in their invoice/warranty page that they replaced it.They read it and said "oh..okay". Then asked to see my car and it started to make the noise when he checked it out and went on to say that it wasn't it. But I told them it is and they said to bring it back Monday so they can check it out.
So i'm asking if anybody can tell by this video if indeed it is and can advise me? Don't want them backing out of their warranty and blaming the noise on something else just so they don't fix it.
https://*******/QCMn
Thank you!
Old Aug 20, 2016 | 10:17 PM
holmesnmanny's Avatar
Default Re: Need Help ! Possible Bad Throw Out Bearing?
They replaced what exactly ?
Old Aug 23, 2016 | 09:48 AM
Achroth's Avatar
They replaced the Gear Pinion and the Counter Shaft. I don't know if they replaced the throw out bearing since I didn't swap out the clutch but they said they did in the Invoice.
Old Aug 25, 2016 | 11:10 PM
Try removing the two slave cylinder bolts and putting grease on the ball end of the pushrod. Put it back together and see if the noise is still there. If you have PB Blaster or Silicone spray you can also just shoot some into that ball and see if the noise goes away. If it does you just need to grease it as stated in the first sentence.
SlimNubster
Honda Civic (2001 - 2005)
Jul 14, 2010 08:10 AM
chrisfromsrq
Sep 17, 2009 12:31 PM
VtecVillan
Nov 5, 2007 12:11 PM
Jeffro_93
12
Oct 10, 2003 03:08 PM
JunIntegra
Oct 1, 2003 04:20 AM
