93 civic starting problem
Old Aug 14, 2016 | 11:07 PM
Dahhhbeed's Avatar
Default 93 civic starting problem
My car needs tlc lol the car started to over heat on me so i took out the thermostat is now running without a thermostat and still over heats! Maybe a new water pump and thermo would make it not over heat????? AND So i recently put a new distributor and fuel pump into the car, starter is fairly new as well, anyway for the first week or two it started fine and quick, but then it went back to its struggling ways of just wanting to start but never turned over, and when it did start it started as if it were struggling to get going and would have to give it gas to get going and also at times it would start and turn right off after a series of attempts . Idk if its a fuel line or something but i cam figure it out. Any ideas why it wont start up normally??
Old Aug 16, 2016 | 10:01 AM
fcm's Avatar
fcm
Old Fart
Default Re: 93 civic starting problem
So your overheating and you replaced the distributor and fuel pump????
Have you done a compression test to see if the overheating has warped the head?
Have you checked the PGM-FI Main Relay, [a common problem]?
Have you pulled the water pump to inspect the blades? 94
Old Aug 16, 2016 | 12:02 PM
Dahhhbeed's Avatar
No lol why would i replace those if my car was over heating? Lol. I already found the problem i need a new water pump!
Old Aug 16, 2016 | 01:19 PM
fcm's Avatar
fcm
Old Fart
Just reading your post, "Maybe a new water pump and thermo would make it not over heat????? AND So i recently put a new distributor and fuel pump into the car", kind of sound like you knew what you needed but installed a distributor and fuel pump instead 94
Old Aug 16, 2016 | 03:26 PM
Dahhhbeed's Avatar
I shouldve broke it down better, so the fuel pump and altenator was to improve the cars starting problem but is somewhat failing. And the water pump and thermo is to improve the over heating . Make sense now? Haha
Old Aug 17, 2016 | 01:39 PM
fcm's Avatar
fcm
Old Fart
Yep. 94
Dahhhbeed
Aug 15, 2016 10:34 AM
Dahhhbeed
Aug 15, 2016 04:55 AM
Dahhhbeed
Engine Management and Tuning
Aug 14, 2016 11:06 PM
abadkevin
Jun 14, 2009 07:28 PM
04accordV6
Apr 5, 2003 07:21 PM
