93 civic ex starting problem
Old Aug 14, 2016 | 11:03 PM
Dahhhbeed's Avatar
Default 93 civic ex starting problem
My car needs tlc lol the car started to over heat on me so i took out the thermostat is now running without a thermostat and still over heats! Maybe a new water pump and thermo would make it not over heat????? AND So i recently put a new distributor, alrenator, and fuel pump into the car, starter is fairly new as well, anyway for the first week or two it started fine and quick, but then it went back to its struggling ways of just wanting to start but never turned over, and when it did start it started as if it were struggling to get going and would have to give it gas to get going and also at times it would start and turn right off after a series of attempts . Idk if its a fuel line or something but i cam figure it out. Any ideas why it wont start up normally??
Old Aug 15, 2016 | 04:55 AM
Former User's Avatar
Default Re: 93 civic ex starting problem
Fix the overheating problem first.
Is the coolant low in the radiator and reservoir? Is there a leak?
Did you bleed the cooling system?
https://honda-tech.com/forums/honda-.../#post38664177
thehatchninja
Oct 4, 2017 02:12 PM
Dahhhbeed
Aug 17, 2016 01:39 PM
Dahhhbeed
Aug 15, 2016 10:34 AM
Dahhhbeed
Engine Management and Tuning
Aug 14, 2016 11:06 PM
DeDonDeRosa
10
Oct 9, 2009 11:43 AM
