why doesn't my car start when it's hot outside
Old 02-24-2003, 07:52 PM
thehatchninja's Avatar
Default why doesn't my car start when it's hot outside
my car (93 accord) doesn't start when it's hot or been sitting in the sun for a while. it cranks but it doesn't turn over....i haven't had the dist. checked/ replaced for a while. Someone said it might be a fuel line relay....what do you think? thanks a lot
this problem is really pissing me off, and i'm almost ready to just take it somewhere, but i really don't have the money....thanks again guys
thehatchninja is offline
Old 02-24-2003, 08:08 PM
Default Re: why doesn't my car start when it's hot outside (thehatchninja)
i think your problem is in the distubitor, i guess there is moisture build up when u in hot area and get into the "ignitor" cause it to malfuntion. try to chek for broken distubitor seal and any physical damage to it.
fob_viet111 is offline
Old 02-25-2003, 12:25 AM
cd5_2NR's Avatar
Default Re: why doesn't my car start when it's hot outside (fob_viet111)
it might be that...i too lived in a hot area...and had a 93ACCORD and at times..i had a hard time starting it up...i was told that the heat affects the battery...at times evaporating its water and whatever else...and it makes it harder to start...just a suggestion...it might be a mechanical problem too...
cd5_2NR is offline
Old 02-25-2003, 03:21 AM
Chiovnidca's Avatar
That's a good description of a bad main relay. Does it have spark when it's acting up? How about fuel presure?
Chiovnidca is offline
Old 02-25-2003, 04:12 AM
Classic main relay symptoms.
Listen for the fuel pump running for about 2 seconds when the ignition is first turned on. If you don't hear it and you have a no-start condition, the main relay is most likely the cause.
Perfectionist is offline
Old 02-25-2003, 04:30 AM
Charlie Moua's Avatar
Default Re: why doesn't my car start when it's hot outside (Perfectionist)
yup it's your MAIN RELAY!
i had this propblem about 8 months ago in my 93 accord. If it's too hot or too cold out the car wouldn't start. But after about 30 mintues i tried starting it agian & the problem went away. It comes back & fourth.
Charlie Moua is offline
Old 02-25-2003, 05:57 AM
D21X's Avatar
Default Re: why doesn't my car start when it's hot outside (Charlie Moua)
anyone know where i can get a main relay for 91 accord for cheap??? i've seen it for about $20 at some honda dealers online. thanks!!!
D21X is offline
Old 02-25-2003, 09:38 AM
MauiBoy056's Avatar
Yeah... It's the fuel relay... Here in Hawaii, especially when it's humid, my Accord will not start.... Hondas are notorious for this (from what I'm told)- I replaced mine
couple years back... It's working fine now.... When I park, I try to look for a shady area to reduce the interior temperature (to be on the safe side)...
If I remember correctly, the relay is located somewhere under the dashboard (nearest to the driver-side airvent)... Hope this helps....
L8z-
Jay
MauiBoy056 is offline
Old 02-25-2003, 01:05 PM
Default Re: why doesn't my car start when it's hot outside (MauiBoy056)
Is it ever not humid in Hawaii?
Old 02-26-2003, 02:26 AM
MauiBoy056's Avatar
It's only humid when there's no wind (sun evaporates surrounding Pacific Ocean- thus creating a "moist"-like,"baking" atmosphere when there's no wind.), or there's a storm approaching the Islands.... 90% of the time, we have "trade winds" that keep the outdoor temperature around the mid-80's (but it's still hot, not humid, enough for my Accord to not start if I park it in the sun ). Typical tropical weather.....
My bad for going off-subject....
L8z-
Jay
Old 02-26-2003, 05:59 AM
philipkrotch's Avatar
mine did that on my last 2. its the distributor
philipkrotch is offline
Old 02-26-2003, 07:25 AM
twkdCD595's Avatar
Default Re: why doesn't my car start when it's hot outside (philipkrotch)
main relay is common thing... had to change one in my old car when I thought I had killed a fuel pump... needless to say is was ok after the relay change.
twkdCD595 is offline
Old 03-03-2003, 08:08 PM
Default Re: why doesn't my car start when it's hot outside (twkdCD595)
this may sound like a really stupid question, but when everybody refers to main relay which relay is that and where is it located in for say a 91 accord?
louder160 is offline
Old 03-04-2003, 02:56 AM
Chiovnidca's Avatar
Default Re: why doesn't my car start when it's hot outside (louder160)
The PGM-FI main relay is under the dash next to the steering column, and above the cruise contrl unit.
Old 03-04-2003, 03:25 PM
Default Re: why doesn't my car start when it's hot outside (D16Chiovnidca)
no I figuered that as much as people talk about the main relay that maybe we should be more specific about which one. Thank you for clearing that up for me at least.
Old 10-04-2017, 12:34 PM
So I have a 1976 Honda Civic CVCC Hondamatic with the same problem.
It ALWAYS starts up fine, unless it's hot outside & even then it's intermittent. Usually happens after I've driven someplace, parked for a couple hours then go back to start the car. When it does this it does not get fuel to the carb. This NEVER happens in the winter - it only happens when it's hot out.
I replaced the main relay, still happens. When I turn the ignition on I do hear the fuel pump going, but I don't smell any gas in the carb. Should I go ahead and replace the fuel pump? Anything else? Nothing is terrible expensive in this car & I keep getting stuck somewhere, so I don't really care about doing process of elimination, I'd rather just replace anything that COULD be causing this problem.
Any advice would be VERY welcome & I promise to follow up with whatever the resolution is!
Thanks!
Rob
Rob Chadwick is offline
Old 10-04-2017, 02:12 PM
can someone move this to the classic honda forum
holmesnmanny is offline
whited
General Discussion and Debate
56
11-20-2017 09:22 PM
TPhilips
10-10-2017 09:35 AM
jack cohen
07-25-2017 05:51 AM
Satish Patel
10-15-2016 12:35 PM
SpoolnByYou
34
07-06-2006 04:42 PM
Quick Reply: why doesn't my car start when it's hot outside
  • Ask a Question
Question Title:
Description:
