Fitting TE37 flat center caps
Old Aug 14, 2016 | 02:59 PM
gambit-irl's Avatar
Default Fitting TE37 flat center caps
Hi has anyone experience in fitting these that know a black art i dont understand?
I have removed both inner and outer rubber O rings.
Cap fits into the hole perfectly.
I then turn wheel unside down and attempt to get the outside ring on (inside ring isnt needed as far as i can see)
Its proving a lot more difficult than i thought,its almost like i havent quiet enough lip on my center cap to get it comfortably around.
I had one half on today but by using an uncomfortable amount of pressure with a small flat head.
Any ideas?
Old Aug 14, 2016 | 09:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Fitting TE37 flat center caps
Lubricate the O-rings with something really slick (Vasaline or clean oil) and then press the caps into the center of the wheel flatly. If this doesn't work, you could try to "angle" them in and use a small flat head screw driver to poke the O-ring in while simutaneously pushing down on the cap.
Old Aug 16, 2016 | 10:05 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ lube up the O-ring and press into place, air tool oil works great. 94
jimmy051702
Nov 5, 2011 11:38 AM
smellykangaroo
Aug 25, 2011 05:58 AM
ef9gsx
Dec 12, 2007 12:57 AM
eLUDEnu
Oct 28, 2004 09:46 AM
blackdc5
Sep 14, 2003 07:46 PM
