Honda CR-V & Element 2WD & 4WD Element & CR-V
Replacement Door Initiates Window Switch Issue
Old Aug 13, 2016 | 11:30 AM
scclark's Avatar
Default Replacement Door Initiates Window Switch Issue
I own a 1999 CR-V and had to replace the front passenger door. As I was installing it, I tried the window switch and found that "down" worked but not "up!" even from the driver's controls. I then swapped the wiring from the old door but no change! I then tested the old door with the old wiring and old switch (by plugging in the wiring harness from the door jamb) and found that neither window will go up once it goes down!!!
I then swapped the switch from the rear door and got the same result. I metered out the front switches and both perform the same (the continuity does change in up and down between the 2 and 4; and the 3 and 4 position wires), which means the switches are good. I attached a solid ground from the frame of the car to the window motor casing in case that was an issue with all of the loose wiring, but I still cannot make the window go up!! This is a true stumper.
I am able to jumper the motor into the closed position (make it go up), so both motors are functional.
Any ideas?
Old Aug 15, 2016 | 04:17 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Replacement Door Initiates Window Switch Issue
Issue is probably due to an open (break) in the wiring or connection. Focus on the wiring and connector at the door jamb area first.
Old Aug 29, 2016 | 05:38 PM
dudie0's Avatar
Yup, sounds like a short. Trace the wire, find where the break is.
JAD
13
Oct 1, 2016 04:05 PM
SoL_ger
Nov 23, 2014 09:47 AM
hughgogh
Jan 24, 2012 11:24 PM
:jdmshmaydm:
Aug 31, 2010 07:34 AM
funkylemons
Audio / Security / Video
Nov 27, 2002 10:50 AM
