Code22 help!!!
Old Aug 13, 2016 | 06:32 AM
Dahhhbeed's Avatar
Default Code22 help!!!
What is the solution to a Code 22 on 93 civic ex coupe d16z6 ??
Old Aug 13, 2016 | 06:51 PM
Epsicle's Avatar
Default Re: Code22 help!!!
I don't know much about Hondas since I'm looking to buy one, but a search showed code 22 as "VTEC pressure valve." You need a certain oil pressure for VTEC to engage, so first make sure you have enough oil in your engine. If your oil is low, add oil to the line and your light should go off. If your oil is fine, test your oil pressure with a gauge (I'm new to Hondas so I don't know where you would attach a gauge). If your pressure is low then my guess is the oil pump is either bad or you've got a dirty pickup for the pump. If your pressure is fine then you probably have a wiring issue with the sensor itself and you should use a voltmeter to test the sensor and the wiring. My personal guess is a wiring issue, but I'm a Ford guy so I don't know.
Old Aug 13, 2016 | 09:40 PM
Dahhhbeed's Avatar
Thanks for your input i really appreciate it !!
Old Aug 14, 2016 | 01:27 AM
holmesnmanny's Avatar
It's entirely possible to have a dent in the oil pan that is preventing sufficient oil pressure to the vtec pressure switch.
1badcrx
Sep 22, 2009 02:00 PM
aznd87
Nov 6, 2006 01:32 PM
BACKintheDA
Jul 12, 2005 01:05 PM
