Annoying ass griding/scraping noise from timing belt area
Old Aug 8, 2016 | 02:15 PM
Russ509's Avatar
Default Annoying *** griding/scraping noise from timing belt area
98 Integra LS has this scratching/grinding sound coming from around the area where the timing belt is on the right side of the engine block. Belts are all in good condition so maybe its just something else in that area, idk wtf it is but its loud af and annoying.
Old Aug 8, 2016 | 05:16 PM
Russ509's Avatar
Default Re: Annoying *** griding/scraping noise from timing belt area
Seriousy , cant get even 1 reply. Help brahs
Old Aug 8, 2016 | 11:48 PM
holmesnmanny's Avatar
Probably the tensioner bearing. 1998 ACURA INTEGRA 1.8L L4 Timing Belt Tensioner | RockAuto
When these go bad, normally because of overtorqued tensioner bolt, it sounds like rocks being shaken in a can when you rev the engine and let it go.
Old Aug 9, 2016 | 05:05 PM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ that is what I would check first.
And get used to waiting more the 3 hr for a reply. 94
sporkcrx
Sep 29, 2005 11:42 AM
94gsr_vtc
Nov 24, 2004 03:45 PM
Thrillhouse
Sep 24, 2002 05:08 PM
