B18C1 GSR VTEC PROBLEM
Hi , i have a problem with my civic 94 with GSR swap the problem is passing 5,800rpm don't pop vtec sound any sound and a few weeks later showed Check engine light and after that always is with Check engine light , what is the problem ? maybe Ecu error with solenid ? or something ? Thank you
I guess it's p72 96-00 i guess that is the ecu but passing 5,800rpm doesn't pop vtec sound and I suppose it is working and i read some post that said when Check Engine is ON the vtec doesn't work I didn't put scanner yet Thanks too answer
5,800 is not the VTEC changeover point. That's when the secondary intake runners open, and unless you have a 94-01 GSR ECU, it's not going to open the intake runners.
