CRX/D16Z6 wideband tuning with Crome wierdness
Old Aug 7, 2016 | 09:41 AM
superccs's Avatar
Default CRX/D16Z6 wideband tuning with Crome wierdness
Just got through tuning my CRX + D16Z6 with IHE (ODB1+MPFI conversion) using Innovate Wideband kit and am pretty happy with the AFRs from idle to WOT. I tuned for 15.5 cruise, 14-14.5 partial and 13.3 WOT with VTEC engaging at 4600rpm. I added a degree of ignition advance at the VTEC engage RPM. Runs well, no knocking detected.
After comparing my map with the basemap it makes me a little confused though, why would the basemap have crossing over fuel values...?
First off the P28 basemap looks pretty wild as a starting point:
https://www.dropbox.com/s/cbqc3uubcc...20lol.JPG?dl=0
https://www.dropbox.com/s/gevm79osx1...20cam.JPG?dl=0
Secondly here are my "final" maps:
https://www.dropbox.com/s/957e9x9fzi...20map.JPG?dl=0
https://www.dropbox.com/s/11orxfr5h7...20cam.JPG?dl=0
I have read that many peeps recommend building off of a P30 base map and then adjusting the fueling accordingly and populating ignition with the p28 values... is that correct? If so what do you gain here if I am
Any recommendations welcome, this is all open to discussion. Also what are your thoughts on smoothing feature and adjusting the fuel to 98% on 5th gear for cruising mpgs.
Thanks!
Old Aug 7, 2016 | 10:40 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: CRX/D16Z6 wideband tuning with Crome wierdness
read the manual in my signature.
Danial
23
Jul 19, 2012 06:44 AM
Barrett24
13
May 8, 2010 06:17 AM
94EGKUSH
Feb 25, 2009 01:02 PM
