Midwest Illinois, Indiana, Iowa, Kansas, Michigan, Minnesota, Missouri, Nebraska, North Dakota, Ohio, South Dakota, Wisconsin
D15b 3 stage vtec( w/ p2j ecu) - Colorado emissions concerns
Old Jul 28, 2016 | 05:41 PM
bassplay's Avatar
assplay
Default D15b 3 stage vtec( w/ p2j ecu) - Colorado emissions concerns
D15b 3 stage> 98 civic
I'm contemplating buying the full d15b 3 stage swap from HMO including the ecu. It's only going in a DD I'm not planning on doing any mods or ****. I'm just interested because I can get this whole swap (motor, trans, harness, ECU) for much cheaper than I have been finding a Y8. Even buying used from eBay the y8 is more expensive and I haven't found and decent motors/Trans in junk yards/CL. So price and availability are pushing me towards the d15b.
So first this thread is NOT about which ecu I need to use to get the motor running. Second the reason for this thread is because almost all the threads about this motor are ECU related and haven't answered any of my questions. I understand that this site is huge on SEARCH but I have and I just need a little guidance and direction.
I'm getting confused with;
If I go to get emissions with the JDM p2j will the scantron fail the car?
What has to be done about the EGR?
I've read people ttalk about needing a Fuel pressure regulator, is this a necessity or something to help tune?
Does the "small case" ECU cause any problems?
Since I'll have the right harness I'm not worried about splicing wiring but the O2 sensor is 5 wires, is that particular O2 sensor hard to find?
Are there any sensors that will need special attention?
Any emissions hiccups going to cause me headaches?
Thanks in advance for aby help or direction to the right answers!
Old Jul 28, 2016 | 09:50 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default re: D15b 3 stage vtec( w/ p2j ecu) - Colorado emissions concerns
The JDM ECU will not be readable with USDM OBD2 scanners and yes, that will fail you regardless of state.
You have to be OBD1, which is 95 or earlier to get away with the JDM ECU and tail pipe sniff testing.
I can't answer the rest, beyond the small case won't fit normally if at all with the stock large ECU spot.
To be absolutely sure though, give your emissions facility a call and ask about running OBD1 in your OBD2 car due to motor replacement. They don't need to know that it's actually a JDM OBD2 motor.
Old Jul 29, 2016 | 12:10 AM
forbiddenera's Avatar
OBD1 is the way to go!
Really, for 98% of what anyone wants to do with most hondas, obd1 is better.
You won't be able to get that motor running obd2 properly for emissions. So glad I don't have to deal with that here.
One suggestion, though id go obd1 first, You could MAYBE run a SIMILAR USDM ECU for emissions ONLY and then use the jdm ecu for DD, but, I'm not sure which would be your best bet, maybe a y8 ecu but..you'd have to make sure you have no codes and the maps are similar, and I'm not sure you could just plug it in and not get codes, may be possible, the main difference is 3 stage vtec.
Even if you got it running on a usdm obd2 ecu with no codes you could still fail sniffing if the maps aren't close enough. I have little idea how emissions testing works though.
Old Jul 29, 2016 | 12:52 AM
tony_2018's Avatar
Fish Twig
Would be nice to know what state you reside in...
Old Jul 29, 2016 | 03:38 AM
bassplay's Avatar
assplay
I kinda figured that they would hook up and immediately see it's not a usdm ecu and fail me. I'll have to call and ask but I'm 99% sure it's got to be the same obd as what was originally in the car.
But how would the obd1 ecu not get flagged as jdm as well, I figured any jdm ecu would not pass us emissions?
Honestly I don't care what one it is I jjust want a simple motor in my DD but not y7 simple ya know a lil pep.
I thought of that too, try using a vtec-e ecu but those are all obd1 as well. And trying to track down what ecu will mot through codes AND have a close enough base map will be a crap shoot. But I did see some threads about using a y8 ecu and such, will have to give them another read.
I absolutely hate emissions I know this car will burn cleaner than 80% of the cars on the road no matter what obd it is
Ugh a b16 is sounding easier and easier as I dig into this
Sorry that would help a bit....Colorado
Thanks for the responses guys!!!!
Old Jul 29, 2016 | 04:46 AM
tony_2018's Avatar
Fish Twig
Have you bothered looking up inspection laws in your county, or city?
Old Jul 29, 2016 | 06:36 AM
eghatch9295's Avatar
Stancetard Hate Monger
would be a good idea to read your emissions laws. for example, here in ohio, if they can't get their equipment to read your obd-2 computer, they allow you to do the sniffer test. a similar loophole in your state would be problem solved.
Old Jul 29, 2016 | 07:03 AM
tony_2018's Avatar
Fish Twig
Regardless, you will not past with the jdm p2j ecu, they can't read it and if they put the sniffer to it you're fucked.
Old Jul 29, 2016 | 07:08 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If the car is OBD1, it was before there was a standard for hookup/communication. Result is that on OBD1 cars they don't scan anything, they do the tail pipe sniff test.
This here is what you should look for. Really need to call your emissions place and see if they auto fail you if they can't read the ECU or if they revert to the sniff test.
I wasn't sure if any states were like that but was hoping.
Also glad you said you aren't in California as then your life would be even more challenging as far as emissions.
Why, what goes up in the lean burn mode? The 25 mile an hour test should be fine, but the lean burn mode is where I suspect the problem lies with the sniff test.
Old Jul 29, 2016 | 08:55 AM
tony_2018's Avatar
Fish Twig
High nox bro...eco mode it leans out, I believe if you have a wide band hooked up it will show ratio is 25:1, or something like that. Been a while since this discussion came up. We discussed it on d-series.org, I found info on wiring as well as did my own investigation for wiring and posted here on HT as well.
edit: depending on what gear they will be in w/ the 25mph test lean burn will kick in. This would still be interesting to test though.
Old Sep 3, 2016 | 08:53 PM
92cxyd's Avatar
Default Re: D15b 3 stage vtec( w/ p2j ecu) - Colorado emissions concerns
could try tank full of ISOpropanol (rubbing alcohol)
Old Sep 4, 2016 | 12:59 PM
D15b isn't really simple with all the problems you listed not to mention the cvt Trans unless yu use another
@Tony what gear would they do the test on with the cvt? Lol
Old Sep 5, 2016 | 06:59 AM
tony_2018's Avatar
Fish Twig
OP never listed what gearing he will use BUT
What OBD1 ecu will control a CVT?
loudnlow ef
Oct 17, 2011 11:44 AM
n_senn
21
Aug 3, 2011 07:30 AM
jestin91
Apr 27, 2011 02:30 AM
hatchizzle
May 30, 2003 12:45 AM
