No start 1996 Civic DX Hatch 5SPD
Old Jul 27, 2016 | 01:15 PM
ej6dx's Avatar
Default No start 1996 Civic DX Hatch 5SPD
Hey guys, I recently purchased this hatchback and the old battery died. My brother removed some ground wires and I believe that he said he got a spark on the fuel rail when it ran for a little bit. I checked all my grounds and they look good. I put a new battery in and the car will not start. I can hear my starter click and my fuel pump prime, fuel is getting from my pump to filter and from the filter to fuel rail, my injectors are ejecting fluid straight. I've replaced all my throttle body sensors and my fuel rail and injectors with OEM. New NGK V-power spark plugs and all new relays all around. Any help would be appreciated. I miss driving my car I'm not the most mechanically inclined so good description would be appreciated.
Old Jul 27, 2016 | 04:25 PM
forbiddenera's Avatar
Default Re: No start 1996 Civic DX Hatch 5SPD
What ground wires did he remove?! If they were any stock grounding points, it could be the cause.
Improper grounding can definitely cause this. The starter is just clicking and not turning OVER? Make sure the starter has a good connection to the battery. I'd check the starter fuse with the 3 steps below and you'll know if power is getting to the fuse and through it, if not, fix, if so, check for voltage at the starter.
Use this method for testing fuses: https://honda-tech.com/forums/honda-...fuses-3079359/
Test all your grounds with a multimeter and check the grounds.
Old Jul 27, 2016 | 09:30 PM
ej6dx's Avatar
I ended up finding the issue, it was a bad regulator. The one that's on my fuel rail to be exact. Started right up after switching it out to another one I had laying around. I appreciate the help
Old Jul 27, 2016 | 09:55 PM
Former User's Avatar
A bad fuel pressure regulator would not cause this^ problem.
Old Jul 28, 2016 | 08:37 AM
chrysler kid's Avatar
If your fuel pressure regulator is sparking you should stop driving the car immediately.
Check all ground connections immediately according to the diagram
Old Jul 28, 2016 | 11:40 AM
fcm's Avatar
fcm
Old Fart
Ditto both the above ^^^^ grounds that "look good" may not be, the best way to check them is to redo them, disconnect/clean/reconnect making sure you clean both the terminal and the contact area and that terminal is tight. 94
nexgen91
Dec 9, 2014 06:47 AM
lif3tak3n
Jun 24, 2014 06:00 AM
civicsi509
Jan 18, 2013 08:39 AM
94b16teg
Oct 20, 2007 08:58 AM
superhatchbackbros
26
Apr 26, 2007 04:44 PM
