EJ9 Track car conversion help?????
Old Jul 26, 2016 | 09:43 AM
MarkEJ9's Avatar
Default EJ9 Track car conversion help?????
been messing with the idea of converting my ej9 d14z2 to d16z6, car is obd2b loom and im aware the z6 was obd1, have a p28 for a z6 and engine waiting if i want it, curious as to what will need to be changed wiring wise and mechanically
ANY HELP WOULD BE GREATLY APPRECIATED,
thanks
Old Jul 27, 2016 | 02:06 AM
forbiddenera's Avatar
Default Re: EJ9 Track car conversion help?????
Again, not familiar with your engine, but with a rywire harness (or diy, rywire easier/safer) you should be able to bolt it in, swap ecu, plug harness and go. You'll keep obd2 sensors and obd2 engine side. Or you can rip out the harness and use a obd1 harness with obd1 sensors but it's way more work.
The obd 2>1 and 1>2 has been covered 1000s of times, search! Not a lot may be particularly specific to the d14, unless you have a 5 wire o2 or something
yajboi
Mar 31, 2010 05:41 PM
Max500
Jun 14, 2009 02:53 PM
97civicgc
19
Jan 20, 2009 10:18 PM
apice
Mar 19, 2008 03:35 PM
stehigs321
Feb 21, 2004 12:03 PM
