Swap nightmare. Need advice
Bought a z6 motor that was taken apart to do an OEM rebuild
Cracked the head on my D15 so now the build had to be rushed because its my daily.
Went to install APR studs in Z6 block and one of the head stud holes is stripped out. Used a helicoil and it worked. Then I noticed the stud was taller in the corner with the vtec solenoid (should've been a clue) Used washer to fill the gap. (I know not the right way to do it.
Finally got the motor in and the Z6 dizzy doesn't fit. Only the top mount lines up.
So I look at the head casting and realize it's a freaking y8 head.
people say use B7 dizzy. Nope. Only 2 side mounts live up.
Z6 timing belt doesn't fit with the Y8 cam gear without it being really tight also had to swap the tensioner with a smaller one. Buy a y8 timing belt and it way to long.
So now my mechanical timing is a mess. tried using the z6 cam gear and it seems to be alot closer which makes no sense to me at all. .
I cannot get the timing right for the life of me. car runs like crap. I found someone selling a z6 shortblock with a rod threw it for $50.
I don't know if I should buy that head and have everything match or keep trying to mess with the z6/y8
I need some opinion because I am at a loss.
I would but I can't afford a whole motor right now and like I said it's my daily so I need it running like yesterday. I can get a Z6 motor that snapped a rod and use the head but Im afraid that it may have messed up the head or valves. I havent seen the motor yet though
z6/y8 timing belts are the same. you sure you're using a b7 distributor? the cases for them and the y7/y8 are the same. if you're having a hard time with a "hybrid" setup, buy the z6 head.
So would the gear need advanced or retarded the 4.75 degree
It might be possible that the previous owner mixed up the cam caps between a Z6 and Y8 head, the far end has one of the flange legs for the distributor and if that's the case that might explain why you can't install either dizzy properly.
I'd be interested in which tensioner you used that is "smaller" because in my experience there were only 2 kinds and they're not interchangeable.
well the guy I was getting the z6 head from showed up with a y8 head. I used the the rocker assembly from that. Now the b7 dizzy fits and the car runs. Found out we were adjusting the valves wrong. Did them the right way and now she runs nice and quiet.
Only issue Im having is that it bogs when giving it gas at low RPM which I'm thinking the coolant needs bled. I did bleed it but there isn't a steady flow of coolant unless I blip the throttle.
I also noticed that sometimes when giving it gas the temp gauge will drop as the RPM goes up and go back to normal as I let off the gas.
cam and cam gear are both y8 crank gear is z6. Ecu is a P28 not chipped
setting tdc on the head is a little confusing to me. I know the "up" should be at 12 o'clock but what about the arrows on the cover
Darrell Woods
11
Feb 9, 2017 08:09 PM
MR.johnson
16
Sep 17, 2008 08:35 PM
The Internet Tough Guy
11
May 3, 2006 05:23 PM
SOHC_MShue
15
Jun 3, 2005 06:18 PM
