99 civic has no power when key is turned
Old Jul 23, 2016 | 01:12 PM
Goobergobbler's Avatar
Default 99 civic has no power when key is turned
I just finished my swap and when I jumped in it and turned the key to on all my gauges and radio turned on then I turned it to start and everything shut down. I turned it off and tried again and nothing happened at all. What happened?
Old Jul 23, 2016 | 06:38 PM
Default Re: 99 civic has no power when key is turned
40a ignition fuse is good and battery has 12.3 volts.
Old Jul 24, 2016 | 05:10 AM
mk378's Avatar
Ground wires hooked up? Connections at the battery secure?
Turn the headlights on, if they do not light take a voltmeter and start measuring for where the voltage is being lost. First measure at the battery posts to confirm the battery is not dead. Then measure from the post to the terminal. There should be zero volts. If a voltage appears between parts that should be connected, it is a bad connection. Do this all the way around the circuit both on the power and the ground side.
Old Jul 24, 2016 | 05:52 AM
Ground wires are good and the battery terminals are tight The headlights do not turn on and the battery is charged. I put two different battery's in the car. Let me make sure I understand this. I need to trace the headlight circuit to figure out where the voltage is being lost? What do you mean from the post to the terminal?
Old Jul 24, 2016 | 07:32 AM
Former User's Avatar
Triple check your wiring job. Something with the main power distribution went wrong.
Start by checking the 80A hood fuse.
https://honda-tech.com/forums/honda-...fuses-3079359/
Old Jul 24, 2016 | 07:52 AM
It's good. All the fuses under good are intAct
Old Jul 24, 2016 | 07:56 AM
Voltage test the 80A and 40A fuses (41 and 42). See link I posted.
Do the hazard lights and horn work?
How do you know? Avoid blanket statements like this unless you are able to back them up.
Old Jul 24, 2016 | 09:55 AM
Ok so both fuses are getting 12.3v on either side of the fuses when I probed the grounds I got 12.3v where the battery ground hits the chassis and at the thermostat ground. I have a nology ground strap running from the head and the block and to the frame. When I probed where it hits the frame it slowly rises from 0v to like 3v and then jumps around between 0-3v. But that wouldn't cause the car to lose power to everything would it?
Old Jul 24, 2016 | 10:59 AM
Not sure why you did not address this^.
Also check the G1 battery and G3 transmission grounds.
Old Jul 25, 2016 | 06:20 AM
I thought I answered you. No the horn nor the hazard lights work. Headlights and blinkers do not work. None of the interior lighting is working as far as the over head lights and any dash lighting including the radio. This is true with the key in every position. The battery ground is getting 12.3v where it meets the chassis. I forgot to test that one I will get back to you with a reading as soon as I get back to the car.
Old Jul 25, 2016 | 06:33 AM
Check the G1 ground wire.
Old Jul 25, 2016 | 02:35 PM
mk378's Avatar
Your grounds are bad. There should be almost zero voltage difference between the battery minus post and the frame. Same thing for the engine.
Old Jul 25, 2016 | 06:30 PM
I just checked all my grounds again and they all read 12.5v even the transmission ground
I'm sorry 12.25v
Old Jul 25, 2016 | 07:27 PM
mk378's Avatar
Put one meter probe on the lead post on the minus side that is part of the battery (not the terminal that is part of the car). Put the other probe on the frame or the engine. The reading should be very close to zero volts.
Do this test with the headlight switch on and/or someone turning the key trying to start.
Old Jul 26, 2016 | 05:38 AM
Old Jul 26, 2016 | 05:00 PM
So this is with the headlight switch on and someone turning the key to start.
Old Jul 26, 2016 | 05:01 PM
Basically the g1 battery ground has to be bad?
Old Jul 27, 2016 | 01:37 AM
forbiddenera's Avatar
Exactly. The voltage reading you are seeing there, assuming you did it right, is voltage grounding thru the multimeter instead of the ground (path of least resistance) as was said that reading should be near zero volts.
Old Jul 27, 2016 | 03:53 PM
That was it. 100% thanks so much guys
Old Jul 27, 2016 | 04:14 PM
Glad to hear it worked out and that you learned something in the process. HT /win.
bump2pass
Apr 4, 2016 07:29 AM
civicboy420
27
Aug 20, 2014 07:53 PM
dudee
Nov 23, 2010 07:34 AM
EF Two
Oct 3, 2003 08:39 PM
WuShu
Jul 15, 2003 07:07 AM
