My 93 del Sol won't run
Old Jul 23, 2016 | 11:29 AM
Antibullllseye's Avatar
Default My 93 del Sol won't run
Hey I have a 93 del Sol with the 1.5 sohc and sometimes it won't start. It will crank over and run for about two seconds then die and not start. Ive cleaned the points and rotor on the distributor butit doesn't seem to have worked. Any help would be great.
Old Jul 23, 2016 | 11:38 AM
Former User's Avatar
Default Re: My 93 del Sol won't run
Last full ignition system tune up?
CEL codes?
Fuel pump primes?
Bright white spark at the plugs?
Mechanical timing good?
Old Jul 23, 2016 | 11:48 AM
Only had the car for a few months so I don't know when the last ignition tune up was havent checked spark or fuel and there is no codes being thrown
Old Jul 23, 2016 | 11:55 AM
Listen for fuel pump priming for 2 seconds when key is turned from OFF to ON(II).
Check for spark: https://honda-tech.com/forums/honda-...blems-2919450/
Pull the CEL codes (see Codes sticky)
After no-start is solved, replace plugs, wires, cap, and rotor.
Old Jul 23, 2016 | 02:56 PM
White_EG1's Avatar
If the fuel pump doesnt prime or it will intermittently, replace your main relay.
Ninebr8kr
14
Mar 20, 2012 08:09 AM
guitarma
Sep 26, 2011 12:46 AM
AaronGeisinger
Dec 11, 2010 05:15 AM
4ghatch
Mar 10, 2007 10:08 PM
